Dear Sir:
Sorry I'm not quite familiar with coding and I was trapped in how to modify IMU-3000 Gyro sampling rate in CC2541DK. Below is TI's open source code for CC2541DK and please help show me how to do it. I'll appreciate the great support from all professional members on this forum. Thanks a lot.
// // Sensors.m // Conlib-Tester // // Created by Ole Andreas Torvmark on 10/2/12. // Copyright (c) 2012 Texas Instruments All rights reserved. // #import "Sensors.h" @implementation sensorC953A @synthesize c1,c2,c3,c4,c5,c6,c7,c8; -(id) initWithCalibrationData:(NSData *)data { self = [[sensorC953A alloc] init]; if (self) { unsigned char scratchVal[16]; [data getBytes:&scratchVal length:16]; self.c1 = ((scratchVal[0] & 0xff) | ((scratchVal[1] << 8) & 0xff00)); self.c2 = ((scratchVal[2] & 0xff) | ((scratchVal[3] << 8) & 0xff00)); self.c3 = ((scratchVal[4] & 0xff) | ((scratchVal[5] << 8) & 0xff00)); self.c4 = ((scratchVal[6] & 0xff) | ((scratchVal[7] << 8) & 0xff00)); self.c5 = ((scratchVal[8] & 0xff) | ((scratchVal[9] << 8) & 0xff00)); self.c6 = ((scratchVal[10] & 0xff) | ((scratchVal[11] << 8) & 0xff00)); self.c7 = ((scratchVal[12] & 0xff) | ((scratchVal[13] << 8) & 0xff00)); self.c8 = ((scratchVal[14] & 0xff) | ((scratchVal[15] << 8) & 0xff00)); } return self; } -(int) calcPressure:(NSData *)data { if (data.length < 4) return -0.0f; char scratchVal[4]; [data getBytes:&scratchVal length:4]; int16_t temp; uint16_t pressure; temp = (scratchVal[0] & 0xff) | ((scratchVal[1] << 8) & 0xff00); pressure = (scratchVal[2] & 0xff) | ((scratchVal[3] << 8) & 0xff00); long long tempTemp = (long long)temp; // Temperature calculation long temperature = ((((long)self.c1 * (long)tempTemp)/(long)1024) + (long)((self.c2) / (long)4 - (long)16384)); NSLog(@"Calculation of Barometer Temperature : temperature = %ld(%lx)",temperature,temperature); // Barometer calculation long long S = self.c3 + ((self.c4 * (long long)tempTemp)/((long long)1 << 17)) + ((self.c5 * ((long long)tempTemp * (long long)tempTemp))/(long long)((long long)1 << 34)); long long O = (self.c6 * ((long long)1 << 14)) + (((self.c7 * (long long)tempTemp)/((long long)1 << 3))) + ((self.c8 * ((long long)tempTemp * (long long)tempTemp))/(long long)((long long)1 << 19)); long long Pa = (((S * (long long)pressure) + O) / (long long)((long long)1 << 14)); return (int)((int)Pa/(int)100); } @end @implementation sensorIMU3000 @synthesize lastX,lastY,lastZ; @synthesize calX,calY,calZ; -(id) init { self = [super init]; if (self) { self.calX = 0.0f; self.calY = 0.0f; self.calZ = 0.0f; } return self; } -(void) calibrate { self.calX = self.lastX; self.calY = self.lastY; self.calZ = self.lastZ; } -(float) calcXValue:(NSData *)data { //Orientation of sensor on board means we need to swap X (multiplying with -1) char scratchVal[6]; [data getBytes:&scratchVal length:6]; int16_t rawX = (scratchVal[0] & 0xff) | ((scratchVal[1] << 8) & 0xff00); self.lastX = (((float)rawX * 1.0) / ( 65536 / IMU3000_RANGE )) * -1; return (self.lastX - self.calX); } -(float) calcYValue:(NSData *)data { //Orientation of sensor on board means we need to swap Y (multiplying with -1) char scratchVal[6]; [data getBytes:&scratchVal length:6]; int16_t rawY = ((scratchVal[2] & 0xff) | ((scratchVal[3] << 8) & 0xff00)); self.lastY = (((float)rawY * 1.0) / ( 65536 / IMU3000_RANGE )) * -1; return (self.lastY - self.calY); } -(float) calcZValue:(NSData *)data { char scratchVal[6]; [data getBytes:&scratchVal length:6]; int16_t rawZ = (scratchVal[4] & 0xff) | ((scratchVal[5] << 8) & 0xff00); self.lastZ = ((float)rawZ * 1.0) / ( 65536 / IMU3000_RANGE ); return (self.lastZ - self.calZ); } +(float) getRange { return IMU3000_RANGE; } @end @implementation sensorKXTJ9 +(float) calcXValue:(NSData *)data { char scratchVal[3]; [data getBytes:&scratchVal length:3]; return ((scratchVal[0] * 1.0) / (256 / KXTJ9_RANGE)); } +(float) calcYValue:(NSData *)data { //Orientation of sensor on board means we need to swap Y (multiplying with -1) char scratchVal[3]; [data getBytes:&scratchVal length:3]; return ((scratchVal[1] * 1.0) / (256 / KXTJ9_RANGE)) * -1; } +(float) calcZValue:(NSData *)data { char scratchVal[3]; [data getBytes:&scratchVal length:3]; return ((scratchVal[2] * 1.0) / (256 / KXTJ9_RANGE)); } +(float) getRange { return KXTJ9_RANGE; } @end @implementation sensorMAG3110 @synthesize lastX,lastY,lastZ; @synthesize calX,calY,calZ; -(id) init { self = [super init]; if (self) { self.calX = 0.0f; self.calY = 0.0f; self.calZ = 0.0f; } return self; } -(void) calibrate { self.calX = self.lastX; self.calY = self.lastY; self.calZ = self.lastZ; } -(float) calcXValue:(NSData *)data { //Orientation of sensor on board means we need to swap X (multiplying with -1) char scratchVal[6]; [data getBytes:&scratchVal length:6]; int16_t rawX = (scratchVal[0] & 0xff) | ((scratchVal[1] << 8) & 0xff00); self.lastX = (((float)rawX * 1.0) / ( 65536 / MAG3110_RANGE )) * -1; return (self.lastX - self.calX); } -(float) calcYValue:(NSData *)data { //Orientation of sensor on board means we need to swap Y (multiplying with -1) char scratchVal[6]; [data getBytes:&scratchVal length:6]; int16_t rawY = ((scratchVal[2] & 0xff) | ((scratchVal[3] << 8) & 0xff00)); self.lastY = (((float)rawY * 1.0) / ( 65536 / MAG3110_RANGE )) * -1; return (self.lastY - self.calY); } -(float) calcZValue:(NSData *)data { char scratchVal[6]; [data getBytes:&scratchVal length:6]; int16_t rawZ = (scratchVal[4] & 0xff) | ((scratchVal[5] << 8) & 0xff00); self.lastZ = ((float)rawZ * 1.0) / ( 65536 / MAG3110_RANGE ); return (self.lastZ - self.calZ); } +(float) getRange { return 60.0; } @end @implementation sensorTMP006 +(float) calcTAmb:(NSData *)data { char scratchVal[data.length]; int16_t ambTemp; [data getBytes:&scratchVal length:data.length]; ambTemp = ((scratchVal[2] & 0xff)| ((scratchVal[3] << 8) & 0xff00)); return (float)((float)ambTemp / (float)128); } +(float) calcTObj:(NSData *)data { char scratchVal[data.length]; int16_t objTemp; int16_t ambTemp; [data getBytes:&scratchVal length:data.length]; objTemp = (scratchVal[0] & 0xff)| ((scratchVal[1] << 8) & 0xff00); ambTemp = ((scratchVal[2] & 0xff)| ((scratchVal[3] << 8) & 0xff00)); float temp = (float)((float)ambTemp / (float)128); long double Vobj2 = (double)objTemp * .00000015625; long double Tdie2 = (double)temp + 273.15; long double S0 = 6.4*pow(10,-14); long double a1 = 1.75*pow(10,-3); long double a2 = -1.678*pow(10,-5); long double b0 = -2.94*pow(10,-5); long double b1 = -5.7*pow(10,-7); long double b2 = 4.63*pow(10,-9); long double c2 = 13.4f; long double Tref = 298.15; long double S = S0*(1+a1*(Tdie2 - Tref)+a2*pow((Tdie2 - Tref),2)); long double Vos = b0 + b1*(Tdie2 - Tref) + b2*pow((Tdie2 - Tref),2); long double fObj = (Vobj2 - Vos) + c2*pow((Vobj2 - Vos),2); long double Tobj = pow(pow(Tdie2,4) + (fObj/S),.25); Tobj = (Tobj - 273.15); return (float)Tobj; } @end @implementation sensorSHT21 +(float) calcPress:(NSData *)data { char scratchVal[data.length]; [data getBytes:&scratchVal length:data.length]; UInt16 hum; float rHVal; hum = (scratchVal[2] & 0xff) | ((scratchVal[3] << 8) & 0xff00); rHVal = -6.0f + 125.0f * (float)((float)hum/(float)65535); return rHVal; } +(float) calcTemp:(NSData *)data { char scratchVal[data.length]; [data getBytes:&scratchVal length:data.length]; UInt16 temp; temp = (scratchVal[0] & 0xff) | ((scratchVal[1] << 8) & 0xff00); return (float)temp; } @end
