cc2541 input with pull-down
Hi
I’m a beginner with electronics and I’m currently trying to work out how to set a pin with internal pull-dow resistor?
As per spec sheet, an input pin is by default set with a pull-up resistor, I need to change P0.0 to be input with pull-dow resistor
P0SEL = 0;
P0DIR = 0xFE; // Port 0 pins P0.0 as input, all others as output
P0 = 0x01; // All pins on port 0 to low except for P0.0
Any help would be appreciated
