Timing entering/exiting power down mode
I need to measure sleep-wake timing balance.
Where (what module/function)  in stack v 1.4 should I toggle a bit to monitor entering/exiting sleep mode (either PM2 or PM3)
    You can use the DCDC bypass signal. look at HCI_EXT_MapPmIoPortCmd in hci.h. The GPIO output chosen will be High on Wake, and Low upon entering Sleep. You should be able to use most pins except for a few such as P2.1 and P2.2 (used by the debug interface).
