How to process barometer sensor reading of cc2650 SensorTag
Other Parts Discussed in Thread: CC2650
I'm trying to measure barometer pressure using cc2650 SensorTag.
The raw value for barometer sensor I'm getting is
f9 78 48 c9
i.e. Barometer MSB : C9
Barometer LSB : 48
F9 and 78 are of temp sensor values.
Now my question is how can I convert this raw barometer values to get actual data ?
Is it possible that I avoid calibration calculations just to get some rough reading ?
  • Hi Waqas,
    Have you read through the datasheet for the pressure sensor?
    Cheers,
    Fredrik
  • Waqas,
    Did you ever get you question answered? You may want to check out this post: e2e.ti.com/.../426866.
    It looks like you are running an older version of the firmware. With 1.12 the barometer sensor returns 6 bytes: Temp(LowByte) Temp(MiddleByte) Temp(HighByte Pressure(LowByte) Pressure(MiddleByte) Pressure(HighByte). To get the temperature or the pressure you take the three bytes and divide by 100. The formula for pressure looks like this:
    ((value[3] & 0xff) + ((value[4]<<8) & 0xff00) + ((value[5]<<16) & 0xff0000)) / 100
    Hope this helps,
    digitalhack
