Choose between CC2541 or CC2640 as begineer?
Other Parts Discussed in Thread: CC2540, CC2640, CC2650, CC2541, CC2541DK-MINI, BLE-STACK
I am new to TI .And this is my first project based on TI products.
My objective is to design a module having BLE and transmit two sensors(humidity and pressure) data through I2C protocol to an iOS and android app.
So as a begginer,should i use CC2540 or CC2640?
Which would be more easier and recommend any development kit for my support(programming and building source code).
i have only one month for this.
  • Hi Ali,
    Although 1 month is a very short time frame to build a quite complex product I would recommend using the CC2650 SensorTag which already has a humidity and pressure sensor using I2C onboard. Example firmware is found in the SensorTag project found in the TI BLE stack v2.1 (ti.com/ble-stack).
    We also have an Android sample app available (https://git.ti.com/sensortag-20-android) and are working to publish an iOS application.
    Svend
  • Thanks for your suggestion.
    But i thought CC2541 is enough for my requirements and its first BLE version,so it would be less complex than cc2640.
    My boss had ordered CC2541DK-MINI kit & CC2541SDK.
    Now i am worried that it can only be programmed to flash through IAR Embedded workbench,its full version is very expensive.Can you please suggest me any remedy for my project, to program 8051 ?
    Or IAR trial version will full fill my code requirements?
  • Hello Ali,
    As explained in the SWDeveloper's Guide, IAR offers a full-featured 30 day trial. You will need to full version when working with the BLE-Stack.
    I don't think you will find the CC2640 complex; there are many examples and documents/wikis to help guide you. As suggested by Svend, please consider ordering the CC2650 SensorTag and CC-Devpack-Debugger. With this kit, you can develop with a free Code Composer Studio license.
    Best wishes
