I have the weird problem that need some help.
We created a profile in our design.
The routine abeacon_ReadAttrCB is not executed even though all the function declaration are correct and look normal.
// Simple Profile Service Callbacks
CONST gattServiceCBs_t abeacon_CBs =
abeacon_ReadAttrCB, // Read callback function pointer
abeacon_WriteAttrCB, // Write callback function pointer
NULL // Authorization callback function pointer
status = GATTServApp_RegisterService(abeaconAttrTbl,
GATT_NUM_ATTRS(abeaconAttrTbl),
GATT_MAX_ENCRYPT_KEY_SIZE, //This is new parameter to support SDK 2.1
&abeacon_CBs);
The application calls
Abeacon_AddService(GATT_ALL_SERVICES);
(I use Btool to scan, connect, and use the command "GATTdiscCharsdesc"
I do not see the function abeacon_ReadAttrCB executed and the display of information of the profile are all wrong.
The other profiles are detected and display information correctly.
