I was wondering how you verified the stack's RSSI computations?
I attached two of our u.fl boards together with an SMA cable. The output of each device was set to 0 dBm. The RSSI was consistently -27dBm. I then attached a 20dB attenuation between them and the RSSI was still -27dBm.
Any thoughts on how to verify the software's reading of RSSI would be greatly appreciated.
Thanks!
