Other Parts Discussed in Thread: CC2640, TPS62740
I am using Cc2640 for my project.Does this require any voltage regulator ?
If you are to use an external regulator with the CC26xx, I recommend the TPS62740 as we use in our external regulator mode reference design,
. This is tested and known to work well with the CC26xx, an appnote with more test results will be available shortly.
