Other Parts Discussed in Thread: CC2564, CC2567
We are currently using PAN1326B modules which uses TI CC2564B chip. We are looking into supporting ANT protocol in the system. I understand that PAN1323 supports triple mode BT Classic, BT LE and ANT whereas PAN1327 supports BT classic and ANT. All these modules are pin compatible with PAN1326B . I have couple of questions.
- If we use PAN1323 or PAN1327 do we need any patches for supporting ANT.
- PAN1323 uses CC2564 device which is not recommended for new design. Is there a problem in using this module.
- PAN 1327 uses CC2567 chip. I did not find any datasheet of this from TI or Panasonic website. Do I need a separate patch for this device if we decide to use this . Where can I find this patch. Is there any change needed in Bluetopia stack to support this device.
- Is there any ANT related demo or example in TI website.
