I am trying to use the TI-BDS-PLUGIN Version 1.0.3 Beta in BDS 1.0.2043 and am getting and error when generating code. I have attached the error log and the BDS project file.
Generating code... Info - Packaging Profile data for the plugin - Texas Instruments CC26xx BLE SDK v2.1 GATT Server plugin Info - Loading the plugin Texas Instruments CC26xx BLE SDK v2.1 GATT Server plugin Info - Validating the plugin Texas Instruments CC26xx BLE SDK v2.1 GATT Server plugin Info - Service name: Device Configuration Info - Processing char: channel Info - 1 fields in char. Info - Total length calculated to: 1 bytes Info - --------------- Info - Generated header file: Fx_TI/Device_Configuration.h Info - Generated code file: Fx_TI/Device_Configuration.c Info - Service name: fx System Configuration Service Info - Processing char: S2 properties Info - 4 fields in char. Info - Total length calculated to: 13 bytes Info - Processing char: S3 properties Info - 4 fields in char. Info - Total length calculated to: 13 bytes Info - Processing char: S4 properties Info - 4 fields in char. Info - Total length calculated to: 13 bytes Info - Processing char: S5 properties Info - 4 fields in char. Info - Total length calculated to: 13 bytes Info - Processing char: S1 properties Info - 4 fields in char. Info - Total length calculated to: 13 bytes Info - --------------- Info - Generated header file: Fx_TI/fx_System_Configuration_Service.h Info - Generated code file: Fx_TI/fx_System_Configuration_Service.c Info - Service name: fx settings service Info - --------------- Info - Generated header file: Fx_TI/fx_settings_service.h Info - Generated code file: Fx_TI/fx_settings_service.c Info - Service name: fx telemetry live service Info - Processing char: GPS Info - 3 fields in char. Info - Total length calculated to: 10 bytes Info - Processing char: accelerometer Info - No field length information available. Using length = 1. Info - 0 fields in char. Info - Total length calculated to: 1 bytes Info - Processing char: altimeter Info - No field length information available. Using length = 1. Info - 0 fields in char. Info - Total length calculated to: 1 bytes Info - --------------- Info - Generated header file: Fx_TI/fx_telemetry_live_service.h Info - Generated code file: Fx_TI/fx_telemetry_live_service.c Info - Service name: battery service Info - Processing char: voltage Info - 1 fields in char. Info - Total length calculated to: 2 bytes Info - --------------- Info - Generated header file: Fx_TI/battery_service.h Info - Generated code file: Fx_TI/battery_service.c Info - Service name: fx telemetry log service Info - Processing char: flights information Info - 2 fields in char. Info - Total length calculated to: 2 bytes Info - Processing char: bulk Info - No field length information available. Using length = 1. Info - 0 fields in char. Info - Total length calculated to: 1 bytes Info - --------------- Info - Generated header file: Fx_TI/fx_telemetry_log_service.h Info - Generated code file: Fx_TI/fx_telemetry_log_service.c Info - An error occurred executing the plugin Error - Error - Bluetooth.D3T.Common.Services.JavaScriptRuntimeException: An error occurred while Invoking the script method - RunPlugin ---> Jint.Runtime.JavaScriptException at Jint.Native.Function.ScriptFunctionInstance.Call(JsValue thisArg, JsValue[] arguments) at Jint.Engine.Invoke(String propertyName, Object thisObj, Object[] arguments) at Jint.Engine.Invoke(String propertyName, Object[] arguments) at Bluetooth.D3T.Common.Services.JSIsolatedProgram.Invoke(String method, Object[] paramData) --- End of inner exception stack trace --- at Bluetooth.D3T.Common.Services.JSIsolatedProgram.<InvokeAsync>d__8.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at Bluetooth.D3T.Common.Service.PluginEngine.<RunPluginInternal>d__4a.MoveNext()
<?xml version="1.0"?> <BDSProject xmlns:xsi="www.w3.org/.../XMLSchema-instance" xmlns:xsd="www.w3.org/.../XMLSchema" Name="fx" LastModified="2015-10-21T06:26:33.6691703-07:00"> <Namespace>org.favionics.</Namespace> <BaseGuid>7c7e83db-d9b5-4ad1-ab44-ec6ccb0e3406</BaseGuid> <Profile Name="org.favionics.profile.fx" XMLFile="Profiles\org.favionics.profile.fx.xml" /> <ServiceFiles> <Service UID="83d54a44-5942-4510-af55-cd7a6c7e5b99" XMLFile="Services\org.favionics.service.device_configuration.xml" UUIDMode="Short"> <CharacteristicFiles> <Characteristic UID="f210103d-31e0-4a61-8b45-2cb3273ac0a2" XMLFile="Characteristics\org.favionics.characteristic.channel.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> </CharacteristicFiles> </Service> <Service UID="611a6e38-c4fc-43e1-8f46-4151e2a6784e" XMLFile="Services\org.favionics.service.fx_system_configuration_service.xml" UUIDMode="Short"> <CharacteristicFiles> <Characteristic UID="12a95572-0fee-4fcc-ba93-01ff4a410bd1" XMLFile="Characteristics\org.favionics.characteristic.s2_properties.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> <Characteristic UID="0fb114a7-9a07-4197-a402-d090b45a6397" XMLFile="Characteristics\org.favionics.characteristic.s3_properties.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> <Characteristic UID="509848ac-25e5-46e9-b969-b0100c62cfbd" XMLFile="Characteristics\org.favionics.characteristic.s4_properties.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> <Characteristic UID="44420c19-8bb2-4889-8911-0751f9c4762d" XMLFile="Characteristics\org.favionics.characteristic.s5_properties.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> <Characteristic UID="5ceba867-abd6-4050-99ac-3bdce3010995" XMLFile="Characteristics\org.favionics.characteristic.s1_properties.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> </CharacteristicFiles> </Service> <Service UID="f01725bb-6c5c-4754-8864-3293cf478487" XMLFile="Services\org.favionics.service.fx_settings_service.xml" UUIDMode="Short"> <CharacteristicFiles /> </Service> <Service UID="592a103f-08d3-4d55-a8de-ea64977921fd" XMLFile="Services\org.favionics.service.fx_telemetry_live_service.xml" UUIDMode="Short"> <CharacteristicFiles> <Characteristic UID="3e6457b5-39ab-4683-8b54-31ef929ac94d" XMLFile="Characteristics\org.favionics.characteristic.gps.xml" UUIDMode="Short"> <DescriptorFiles> <Descriptor UID="27f1993a-083f-422b-83ae-c7ab694c64ee" XMLFile="Descriptors\org.favionics.descriptor.new_descriptor.xml" UUIDMode="Short" /> </DescriptorFiles> </Characteristic> <Characteristic UID="d1ad0ae3-52c0-48e8-a1fa-6300fe0b0779" XMLFile="Characteristics\org.favionics.characteristic.accelerometer.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> <Characteristic UID="771c0864-e666-4c9f-adc3-bd97fad9af73" XMLFile="Characteristics\org.favionics.characteristic.altimeter.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> </CharacteristicFiles> </Service> <Service UID="56f1b18a-d465-4acd-aabd-2ea5732b4900" XMLFile="Services\org.favionics.service.battery_service.xml" UUIDMode="Short"> <CharacteristicFiles> <Characteristic UID="72966bff-5fec-4c9b-aa30-5f07650f64c8" XMLFile="Characteristics\org.favionics.characteristic.voltage.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> </CharacteristicFiles> </Service> <Service UID="a0038b30-0ec9-4382-8a42-fe05f8ccd976" XMLFile="Services\org.favionics.service.fx_telemetry_log_service.xml" UUIDMode="Short"> <CharacteristicFiles> <Characteristic UID="184bdcd8-b99b-4766-8303-665bd16d914e" XMLFile="Characteristics\org.favionics.characteristic.flights_information.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> <Characteristic UID="fe19b9e9-bde2-4a73-8ab8-03f13e502534" XMLFile="Characteristics\org.favionics.characteristic.bulk.xml" UUIDMode="Short"> <DescriptorFiles /> </Characteristic> </CharacteristicFiles> </Service> </ServiceFiles> <Workbench> <Client Name="Virtual Client" /> <Peripheral Name="Virtual Server" /> </Workbench> <SavePath>C:\ti\shared\ble\fx.bds</SavePath> <PublishData> <Category /> <LastPublishDate>0</LastPublishDate> <Annotations>true</Annotations> <Emulation>true</Emulation> </PublishData> </BDSProject>
