Other Parts Discussed in Thread: CC2564MODN, CC2564
My customer has some questions regarding the performance differences between the CC2564 and the CC2564MODN:
- In CC2564MODN, the EDR and BLE receiver sensitivities are reduced by 2-3 dB. Can you please provide some insight into the root cause of this reduction?
- Are the receiver sensitivity values found in CC2564 datasheet (not module) measured on the EVB before the front end band-pass filter or after the filter at the input of the CC2564 BT_RF PIN? I am asking to try and figure out why the CC2564MODN has reduced sensitivity.
- The carrier frequency stability on the CC2564MODN is degraded (per the datasheet) from +/- 5 KHz (on the CC2564) to +/- 10 KHz. With Bluetooth specification requiring <= 10 KHz, have you experienced any field issues with CC2564MODN regulatory certification relating this this? Again, any insight into this performance reduction would help?
- Similarly, the adjacent channel power ratio is also degraded by 3-6 dB on the CC2564MODN. Is this attributed to the performance difference between the band-pass filter implementation in the CC2564MODN and the Murata LFB212G45SG8C341 on the CC2564 EVB?
- The maximum usable input power is reduced by 5 dBm on the CC2564MODN. Again, any insights would be helpful.
Josh
