CC2640: Accessing Packet Error Rate Info under DTM LE Receiver Test
Would we able to access the packet error rate data during or after completed the HCI_LE_Receiver_Test described in this link?
  • If you read further down on that page it refers to a response with the number of packets received:
    After sending the HCI_LE_Test_End command to the device, the following response will be returned, indicating that the command was received and the test has ended:
    04 0e 06 01 1f 20 00 xx xx
    xx xx = 00 00 if Tx test was performed
    xx xx = Total number of received packets if Rx test was performed.
