I'm trying to debug the SimpleBLEperipheral example on my smartrf06eb board, but it gives me warning.
That is the error message :
"The stack pointer for stack 'CSTACK' (currently 0x20001A80) is outside the stack range (0x20003FC0 to 0x200043C0) "
The firmware runs untill ICall_createRemoteTasks(); and stops there.
In assembly debug it just goes between those:
0x1001bbd6: 0x2a00 CMP R2, #0
0x1001bbd8: 0xd0fd BEQ.N 0x1001bbd6
Snapshot :
Linker fie :
Filename: cc26xx_ble_app.icf
Revised: $Date: 2014-03-25 14:18:47 -0700 (Tue, 25 Mar 2014) $
Revision: $Revision: 37873 $
Description: IAR ARM Linker Configuration File - BLE Application
Imported Symbols
Note: Linker defines are located in the IAR IDE project using --config_def
in Options->Linker->Extra Options.
CCxxxx: Device Name (e.g. CC2650)
Exported Symbols
Note: Can be used as externs in C code.
STACK_TOP: Location of the top of RAM.
Copyright 2013-2014 Texas Instruments Incorporated. All rights reserved.
IMPORTANT: Your use of this Software is limited to those specific rights
granted under the terms of a software license agreement between the user
who downloaded the software, his/her employer (which must be your employer)
and Texas Instruments Incorporated (the "License"). You may not use this
Software unless you agree to abide by the terms of the License. The License
limits your use, and you acknowledge, that the Software may not be modified,
copied or distributed unless embedded on a Texas Instruments microcontroller
or used solely and exclusively in conjunction with a Texas Instruments radio
frequency transceiver, which is integrated into your product. Other than for
the foregoing purpose, you may not use, reproduce, copy, prepare derivative
works of, modify, distribute, perform, display or sell this Software and/or
its documentation for any purpose.
YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
PROVIDED “AS IS” WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
(INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
Should you have any questions regarding your right to use this Software,
contact Texas Instruments Incorporated at www.TI.com.
// Memory Sizes
define symbol RAM_SIZE = 0x00005000; // 20K
define symbol FLASH_SIZE = 0x00020000; // 128K
define symbol ROM_SIZE = 0x0001C000; // 115K
// Memory Definitions
// RAM
define symbol RAM_START = 0x20000000;
if ( isdefinedsymbol(ICALL_RAM0_ADDR) )
define symbol RAM_END = (ICALL_RAM0_ADDR-1);
else // default
define symbol RAM_END = 0x200027FF;
// Flash
define symbol FLASH_START = 0x00000000;
if ( isdefinedsymbol(ICALL_STACK0_ADDR) )
define symbol FLASH_END = (ICALL_STACK0_ADDR-1);
else // default
define symbol FLASH_END = 0x00007FFF;
// Stack
define symbol STACK_SIZE = 0x400;
define symbol STACK_START = RAM_END + 1;
define symbol STACK_END = STACK_START - STACK_SIZE;
define block CSTACK with alignment = 8, size = STACK_SIZE { section .stack };
define symbol STACK_TOP = RAM_END + 1;
export symbol STACK_TOP;
// Heap
define symbol HEAP_SIZE = 0x1000;
define block HEAP with alignment = 8, size = HEAP_SIZE { };
// Flash Interrupt Vector Table
define symbol INTVEC_NUM_ENTRIES = 50 + 1; // first entry is stack location
define symbol INTVEC_SIZE = INTVEC_NUM_ENTRIES + 4;
// Memory Regions
define memory mem with size = 4G;
define region RAM = mem:[from RAM_START to RAM_END];
define region FLASH_LAST_PAGE = mem:[from(FLASH_SIZE) - 0x1000 to FLASH_SIZE-1];
define region FLASH = mem:[from FLASH_START to FLASH_END]
| FLASH_LAST_PAGE;
// Memory Placement
// CCFG
place at end of FLASH_LAST_PAGE { readonly section .ccfg };
keep { section .ccfg };
// Interrupt Vector Table
place at address mem:FLASH_START { readonly section .intvec };
keep { readonly section .intvec };
// RAM Vector Table
place at start of RAM { section .vtable_ram };
// Stack
place at end of RAM { block CSTACK };
// Heap
place in RAM { block HEAP };
place in FLASH { readonly };
place in RAM { readwrite };
// Initialization
initialize by copy { readwrite };
do not initialize
section .noinit,
section .stack,
if(isdefinedsymbol(RTOS_ROM)) {
if(RTOS_ROM == 1) {
include "cc26xx_rtos_rom.icf";
Any help would be appreciated.
Rajneesh
