Recovering CC2640
Other Parts Discussed in Thread: CC2640
we are using CCS and have programmed our custom board with our experimental firmware. However, on reset we realised that CCS is no longer able to connect to the board. we tried mass erase using FP2 and though FP2 was able to enumerate the device as a CC2640 it failed giving an error mesage that XBAL object not created.
we tried programming the same firmware on another board and ended up bricking that board as well.
I want to know if there there is any method by which we can connect to the board and do a mass erase. as I wrote, FP2 does seem to enumerate the board when we do a power reset. However, when we perform a connect, it gives an error.
We are using an Olimex XDS100v3 debugger (2 wire Jtag). The setup works for our usual firmware. however programming the experimental firmware has made them unresponsive.
Any help would be appreciated.
Sayu
