CC2650 : TELEC Certification
Other Parts Discussed in Thread: CC2650
To whom it may concerned
Our customer would like to pass TELEC certification by coping PCB of CC2650EMK-7ID.
Are there any test data for TELEC certification?
Your reply would be appreciated.
Thanks and best regards.
  • The CC2650 is tested for EN 300 328 and EN 300 440 Class 2(Europe), FCC CFR47 Part 15 (US) and ARIB STD- T66 (Japan) compliance and is Bluetooth certified, please refer to  . For FCC/EN testing, as stated in the aforementioned wiki, you may only reuse a regulatory certification if you are using the *exact* module that is certified. However, all the tools are available in the BLE-Stack for you to run these tests in order to achieve regulatory certification assuming that you have followed the TI HW design recommendations. Using our BLE Stack, your product can inherit the BLE-Stack QDID for Host, Controller & Profile component certification, but will require a separate RF-PHY test.
