I am using sensortag through SmartRfFlash Evaluation board 10-Pin Debug connector. Everything was working fine where I was able to debug, load new program before I strucked to the following error while using debugger:
(Error -241 @ 0x0) A router subpath could not be accessed. A security error has probably occurred. (Emulation package 6.0.222.0)
I search on forum where they suggest Force mass erase using SmartRfFlashProgrammer. I have done mass erase with SmartRfFlashProgrammer where I am getting following message in status box:
>Initiate access to target: XDS-06EB12210ED1A.
>Failed to read target memory.
>Error while reading memory range. Address 0x40091090.
>Start flash erase ...
>Erase finished successfully.
>Reset target ...
>Reset of target successfull.
After again trying to use debugger, getting same error as before. Has anyone face such issue before. It will be great if someone help me to sort out these issue.
Thanks in advance!
NOTE: You can find attached image of error where first one with SmartRfFlashProgrammer and second one while using debugger.
