How to Stop advertising after dsiconnection ?
Hi , i'm working on the KeyFob example.  I noticied that the Keyfob restart advertising automatically after connection lost or disconnecting from master. I want to cancel that. How to do ?
I find this function in peripheral.c , i htink it's responsable for that . What shoud i change in it exactly ?
static void gapRole_ProcessGAPMsg( gapEventHdr_t *pMsg )
  uint8 notify = FALSE;   // State changed notify the app? (default no)
  switch ( pMsg->opcode )
    case GAP_DEVICE_INIT_DONE_EVENT:
        gapDeviceInitDoneEvent_t *pPkt = (gapDeviceInitDoneEvent_t *)pMsg;
        bStatus_t stat = pPkt->hdr.status;
        if ( stat == SUCCESS )
          // Save off the generated keys
          VOID osal_snv_write( BLE_NVID_IRK, KEYLEN, gapRole_IRK );
          VOID osal_snv_write( BLE_NVID_CSRK, KEYLEN, gapRole_SRK );
          // Save off the information
          VOID osal_memcpy( gapRole_bdAddr, pPkt->devAddr, B_ADDR_LEN );
          gapRole_state = GAPROLE_STARTED;
          // Update the advertising data
          stat = GAP_UpdateAdvertisingData( gapRole_TaskID,
                              TRUE, gapRole_AdvertDataLen, gapRole_AdvertData );
        if ( stat != SUCCESS )
          gapRole_state = GAPROLE_ERROR;
        notify = TRUE;
      break;
    case GAP_ADV_DATA_UPDATE_DONE_EVENT:
        gapAdvDataUpdateEvent_t *pPkt = (gapAdvDataUpdateEvent_t *)pMsg;
        if ( pPkt->hdr.status == SUCCESS )
          if ( pPkt->adType )
            // Setup the Response Data
            pPkt->hdr.status = GAP_UpdateAdvertisingData( gapRole_TaskID,
                              FALSE, gapRole_ScanRspDataLen, gapRole_ScanRspData );
          else if ( ( gapRole_state != GAPROLE_ADVERTISING )   &&
                    ( gapRole_state != GAPROLE_CONNECTED_ADV ) &&
                    ( osal_get_timeoutEx( gapRole_TaskID, START_ADVERTISING_EVT ) == 0 ) )
            // Start advertising
            VOID osal_set_event( gapRole_TaskID, START_ADVERTISING_EVT );
        if ( pPkt->hdr.status != SUCCESS )
          // Set into Error state
          notify = TRUE;
      break;
    case GAP_MAKE_DISCOVERABLE_DONE_EVENT:
    case GAP_END_DISCOVERABLE_DONE_EVENT:
        gapMakeDiscoverableRspEvent_t *pPkt = (gapMakeDiscoverableRspEvent_t *)pMsg;
          if ( pMsg->opcode == GAP_MAKE_DISCOVERABLE_DONE_EVENT )
            if (gapRole_state == GAPROLE_CONNECTED)
              gapRole_state = GAPROLE_CONNECTED_ADV;
            else if (gapRole_AdvEnabled)
              gapRole_state = GAPROLE_ADVERTISING;
            else
              gapRole_state = GAPROLE_ADVERTISING_NONCONN;
          else // GAP_END_DISCOVERABLE_DONE_EVENT
            if (gapRole_AdvertOffTime != 0)
              if ( (gapRole_AdvEnabled) || (gapRole_AdvNonConnEnabled) )
                 VOID osal_start_timerEx( gapRole_TaskID, START_ADVERTISING_EVT, gapRole_AdvertOffTime );
            else
              // Since gapRole_AdvertOffTime is set to 0, the device should not
              // automatically become discoverable again after a period of time.
              // Set enabler to FALSE; device will become discoverable again when
              // this value gets set to TRUE
              if ( gapRole_AdvEnabled == TRUE )
                gapRole_AdvEnabled = FALSE;
              else
                gapRole_AdvNonConnEnabled = FALSE;
            // Update state.
            if ( gapRole_state == GAPROLE_CONNECTED_ADV )
              // In the Advertising Off period
              gapRole_state = GAPROLE_CONNECTED;
            else
              gapRole_state = GAPROLE_WAITING;
        else
        notify = TRUE;
      break;
    case GAP_LINK_ESTABLISHED_EVENT:
        gapEstLinkReqEvent_t *pPkt = (gapEstLinkReqEvent_t *)pMsg;
          VOID osal_memcpy( gapRole_ConnectedDevAddr, pPkt->devAddr, B_ADDR_LEN );
          gapRole_ConnectionHandle = pPkt->connectionHandle;
          if ( gapRole_RSSIReadRate )
            // Start the RSSI Reads
            VOID osal_start_timerEx( gapRole_TaskID, RSSI_READ_EVT, gapRole_RSSIReadRate );
          // Store connection information
          gapRole_ConnInterval = pPkt->connInterval;
          gapRole_ConnSlaveLatency = pPkt->connLatency;
          gapRole_ConnTimeout = pPkt->connTimeout;
          // Check whether update parameter request is enabled
          if ( gapRole_ParamUpdateEnable == TRUE )
            // Get the minimum time upon connection establishment before the
            // peripheral can start a connection update procedure.
            uint16 timeout = GAP_GetParamValue( TGAP_CONN_PAUSE_PERIPHERAL );
            osal_start_timerEx( gapRole_TaskID, START_CONN_UPDATE_EVT, timeout*1000 );
          // Notify the Bond Manager to the connection
          VOID GAPBondMgr_LinkEst( pPkt->devAddrType, pPkt->devAddr, pPkt->connectionHandle, GAP_PROFILE_PERIPHERAL );
        else if ( pPkt->hdr.status == bleGAPConnNotAcceptable )
          // Go to WAITING state, and then start advertising
        else
        notify = TRUE;
      break;
    case GAP_LINK_TERMINATED_EVENT:
        gapTerminateLinkEvent_t *pPkt = (gapTerminateLinkEvent_t *)pMsg;
        VOID GAPBondMgr_ProcessGAPMsg( (gapEventHdr_t *)pMsg );
        osal_memset( gapRole_ConnectedDevAddr, 0, B_ADDR_LEN );
        // Erase connection information
        gapRole_ConnInterval = 0;
        gapRole_ConnSlaveLatency = 0;
        gapRole_ConnTimeout = 0;
        // Cancel all connection parameter update timers (if any active)
        VOID osal_stop_timerEx( gapRole_TaskID, START_CONN_UPDATE_EVT );
        VOID osal_stop_timerEx( gapRole_TaskID, CONN_PARAM_TIMEOUT_EVT );
        notify = TRUE;
        gapRole_ConnectionHandle = INVALID_CONNHANDLE;
        // If device was advertising when connection dropped
        if (gapRole_AdvNonConnEnabled)
          // Continue advertising.
        // Else go to WAITING state.
        else
          if( pPkt->reason == LL_SUPERVISION_TIMEOUT_TERM )
            gapRole_state = GAPROLE_WAITING_AFTER_TIMEOUT;
          else
          // Start advertising, if enabled.
      break;
    case GAP_LINK_PARAM_UPDATE_EVENT:
        gapLinkUpdateEvent_t *pPkt = (gapLinkUpdateEvent_t *)pMsg;
        // Cancel connection param update timeout timer (if active)
          // Store new connection parameters
          // Make sure there's no pending connection update procedure
          if ( osal_get_timeoutEx( gapRole_TaskID, START_CONN_UPDATE_EVT ) == 0 )
            // Notify the application with the new connection parameters
            if ( pGapRoles_ParamUpdateCB != NULL )
              (*pGapRoles_ParamUpdateCB)( gapRole_ConnInterval,
                                          gapRole_ConnSlaveLatency,
                                          gapRole_ConnTimeout );
      break;
    default:
      break;
  if ( notify == TRUE )
    // Notify the application with the new state change
    if ( pGapRoles_AppCGs && pGapRoles_AppCGs->pfnStateChange )
      pGapRoles_AppCGs->pfnStateChange( gapRole_state );
    After the device is disconnected (GAP_LINK_TERMINATED_EVENT for example), you need to get rid of the lines that begin advertisements. For examples, the code above shows that if the device was not already advertising, this is called:
    You would want to get rid of this command.
    -Nathan
  • Ok thanks, !! i did that but it dosen't work, why ?
    I modified like follow :
    gapRole_AdvEnabled=FALSE;
    Now VOID osal_set_event( gapRole_TaskID, START_ADVERTISING_EVT ); has no effect, so it's better to comment it.
    You should step through with the debugger to find which command is starting the advertising after the disconnection. Depending on whether your device was advertising when it disconnected and other variables, there could be multiple places where the advertising is being restarted. You'll want to remove whatever command is doing this.
    -Nathan
