error when performing pre-build
Other Parts Discussed in Thread: CC2650STK, CC2650, CC2640
Hello
I download the example "simple_peripheral" on my personal directory.
I modified the argument variables :
TI_RTOS_DRIVERS_BASE = C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\tidrivers_cc13xx_cc26xx_2_20_01_10\packages
BIOS_BASE = C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\bios_6_46_01_38\packages
XDCPATH = C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\tidrivers_cc13xx_cc26xx_2_20_01_10\packages;C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\bios_6_46_01_38\packages
CC26XXWARE = C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\cc26xxware_2_24_02_17393
XDCROOT = C:\ti\xdctools_3_32_00_06_core
SRC_EX = C:\ti\simplelink\ble_sdk_2_02_01_18\src
SRC_BLE_CORE = C:\ti\simplelink\ble_sdk_2_02_01_18\src
SRC_COMMON = C:\ti\simplelink\ble_sdk_2_02_01_18\src\components
TOOLS_BLE = C:\ti\simplelink\ble_sdk_2_02_01_18\tools
ROM = C:\ti\simplelink\ble_sdk_2_02_01_18\src\rom
if i compil the projet "cc2650stk_app - FlashOnly_OAD_ExtFlash" from "C:\ti\simplelink\ble_sdk_2_02_01_18\examples\cc2650stk\simple_peripheral\iar" the compil is OK.
But if i compil the projet "cc2650stk_app - FlashOnly_OAD_ExtFlash" from my personal directory there is a error.
Building configuration: cc2650stk_app - FlashOnly_OAD_ExtFlash
Updating build tree...
Performing Pre-Build Action
Error while running "C:\ti\xdctools_3_32_00_06_core/xs" --xdcpath="C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\
tidrivers_cc13xx_cc26xx_2_20_01_10\packages;C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\bios_6_46_01_38\packages"
iar.tools.configuro -c "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm" --cc "C:\Program Files (x86)\IAR Systems\
Embedded Workbench 7.5\arm\bin\iccarm.exe" --device "CC2650F128" --compileOptions "-D CC2650STK -D CC26XX -D Display_DISABLE_ALL
-D FEATURE_OAD -D HAL_IMAGE_E -D HEAPMGR_SIZE=0 -D ICALL_MAX_NUM_ENTITIES=6 -D ICALL_MAX_NUM_TASKS=3 -D POWER_SAVING -D
SENSORTAG_HW -D USE_ICALL -D xdc_runtime_Assert_DISABLE_ALL -D xdc_runtime_Log_DISABLE_ALL --diag_suppress Pa050 -o D:\
Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\P982213\iar\app\FlashOnly_OAD_ExtFlash\Obj --debug --endian=little
--cpu=Cortex-M3 -f C:\ti\simplelink\ble_sdk_2_02_01_18\src/config/build_components.opt -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\
Conception\Logiciel\P982213\iar\app\stack\build_config.opt -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\P982213\
iar\app\config\configPkg\compiler.opt.defs -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\P982213\iar\app\config\
iar_boundary.bdef -e --fpu=None --dlib_config \"C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\INC\c\
DLib_Config_Normal.h\" -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/controller/cc26xx/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\
src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/common/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/icall/inc\ -I C:\
ti\simplelink\ble_sdk_2_02_01_18\src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/profiles/dev_info\ -I C:\ti\simplelink\
ble_sdk_2_02_01_18\src/profiles/oad/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/profiles/roles\ -I C:\ti\simplelink\
ble_sdk_2_02_01_18\src/profiles/roles/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/profiles/simple_profile\ -I C:\ti\
simplelink\ble_sdk_2_02_01_18\src/profiles/simple_profile/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/target\ -I C:\ti\
simplelink\ble_sdk_2_02_01_18\src\components/hal/src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\
components/hal/src/target/_common\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\components/hal/src/target/_common/cc26xx\ -I C:\ti\
simplelink\ble_sdk_2_02_01_18\src\components/hal/src/target/cc2650/rom\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\
components/heapmgr\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\components/icall/src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\
src\components/osal/src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\components/services/src/saddr\ -I C:\ti\simplelink\
ble_sdk_2_02_01_18\src\components/services/src/sdata\ -I C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\cc26xxware_2_24_02_17393\
-I C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\tidrivers_cc13xx_cc26xx_2_20_01_10\packages/ti/mw/extflash\ -Ohz"
--linkOptions "-o D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\P982213\iar\app\FlashOnly_OAD_ExtFlash\Exe\
simple_peripheral_cc2650stk_app.out --config_def APP_IMAGE_START=0x1000 --map D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\
Logiciel\P982213\iar\app\FlashOnly_OAD_ExtFlash\List\simple_peripheral_cc2650stk_app.map --config C:\ti\simplelink\
ble_sdk_2_02_01_18\src/common/cc26xx/iar/cc26xx_app_oad.icf --keep __vector_table -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\
Conception\Logiciel\P982213\iar\app\..\config\configPkg\linker.cmd -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\
P982213\iar\app\..\config\iar_boundary.xcl C:\ti\simplelink\ble_sdk_2_02_01_18\src\rom\common_rom_releases\03282014\
common_rom.symbols C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\cc26xxware_2_24_02_17393\driverlib\bin\iar\driverlib.lib
--entry __iar_program_start --fill 0xFF;0x1002-0xefff --vfe" --profile release --projFile "D:\Mes_Donnees_SO_GRICE\Travail\ERA01\
Conception\Logiciel\P982213\iar\app\cc2650stk_app.ewp" --cfgArgs NO_ROM=1,OAD_IMG_E=1
Total number of errors: 1
Total number of warnings: 0
Thanks for your help
    Did you enable output messages to 'All' in IAR? If not, please update your post with the verbose log.
    Also, can you explain how you split your project across difference drive letters? It looks like the SDK in on C: and the project is on D:.
    Best wishes
  • Hello
    Yes, my SDK is located in the C drive and my personnal directory is on D drive.
    all my project are stored on D drive to easily back up my work.
    attached th log with verbose.
    "C:\ti\xdctools_3_32_00_06_core/xs" --xdcpath="C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\tidrivers_cc13xx_cc26xx_2_20_01_10\
    packages;C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\bios_6_46_01_38\packages" iar.tools.configuro -c "C:\Program Files (x86)\
    IAR Systems\Embedded Workbench 7.5\arm" --cc "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\bin\iccarm.exe"
    --device "CC2650F128" --compileOptions "-D CC2650STK -D CC26XX -D Display_DISABLE_ALL -D FEATURE_OAD -D HAL_IMAGE_E -D
    HEAPMGR_SIZE=0 -D ICALL_MAX_NUM_ENTITIES=6 -D ICALL_MAX_NUM_TASKS=3 -D POWER_SAVING -D SENSORTAG_HW -D USE_ICALL -D
    xdc_runtime_Assert_DISABLE_ALL -D xdc_runtime_Log_DISABLE_ALL --diag_suppress Pa050 -o D:\Mes_Donnees_SO_GRICE\Travail\ERA01\
    Conception\Logiciel\P982213\iar\app\FlashOnly_OAD_ExtFlash\Obj --debug --endian=little --cpu=Cortex-M3 -f C:\ti\simplelink\
    ble_sdk_2_02_01_18\src/config/build_components.opt -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\P982213\iar\app\
    stack\build_config.opt -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\P982213\iar\app\config\configPkg\
    compiler.opt.defs -f D:\Mes_Donnees_SO_GRICE\Travail\ERA01\Conception\Logiciel\P982213\iar\app\config\iar_boundary.bdef -e
    --fpu=None --dlib_config \"C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\INC\c\DLib_Config_Normal.h\" -I C:\ti\
    simplelink\ble_sdk_2_02_01_18\src/controller/cc26xx/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/inc\ -I C:\ti\simplelink\
    ble_sdk_2_02_01_18\src/common/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/icall/inc\ -I C:\ti\simplelink\
    ble_sdk_2_02_01_18\src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/profiles/dev_info\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\
    src/profiles/oad/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/profiles/roles\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\
    src/profiles/roles/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/profiles/simple_profile\ -I C:\ti\simplelink\
    ble_sdk_2_02_01_18\src/profiles/simple_profile/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src/target\ -I C:\ti\simplelink\
    ble_sdk_2_02_01_18\src\components/hal/src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\components/hal/src/target/_common\ -I
    C:\ti\simplelink\ble_sdk_2_02_01_18\src\components/hal/src/target/_common/cc26xx\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\
    components/hal/src/target/cc2650/rom\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\components/heapmgr\ -I C:\ti\simplelink\
    ble_sdk_2_02_01_18\src\components/icall/src/inc\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\components/osal/src/inc\ -I C:\ti\
    simplelink\ble_sdk_2_02_01_18\src\components/services/src/saddr\ -I C:\ti\simplelink\ble_sdk_2_02_01_18\src\
    components/services/src/sdata\ -I C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08\products\cc26xxware_2_24_02_17393\ -I C:\ti\
    tirtos_cc13xx_cc26xx_2_20_01_08\products\tidrivers_cc13xx_cc26xx_2_20_01_10\packages/ti/mw/extflash\ -Ohz" --linkOptions "-o D:\
    Using RTSC configuration file: D:/Mes_Donnees_SO_GRICE/Travail/ERA01/Conception/Logiciel/P982213/iar/app/../config/app_ble.cfg...
    configuring app_ble.xrm3 from package/cfg/app_ble_prm3.cfg ...
    js: "D:/Mes_Donnees_SO_GRICE/Travail/ERA01/Conception/Logiciel/P982213/iar/config/app_ble.cfg", line 1: Error: Can't find import
    file: '../../../../../src/common/cc26xx/kernel/cc2640/config/cc2640.cfg' (not found along 'D:\Mes_Donnees_SO_GRICE\Travail\ERA01\
    config;.;C:/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/tidrivers_cc13xx_cc26xx_2_20_01_10/packages;C:/ti/tirtos_cc13xx_cc26xx_2_
    20_01_08/products/bios_6_46_01_38/packages;C:/ti/xdctools_3_32_00_06_core/packages;..;C:/ti/xdctools_3_32_00_06_core;C:/ti/xdctoo
    ls_3_32_00_06_core/etc;C:\ti\xdctools_3_32_00_06_core/include;C:\ti\xdctools_3_32_00_06_core/packages')
    "./package/cfg/app_ble_prm3.cfg", line 175
    xdctools_3_32_00_06_core\gmake.exe: *** [package/cfg/app_ble_prm3.xdl] Error 1
    js: "C:/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/bios_6_46_01_38/packages/iar/tools/configuro/Main.xs", line 133: Error:
    xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    Your error is here:
    You will need to copy the contents of the cc2640.cfg file to your app_ble.cfg file. There may be other build errors after address this one; using the verbose log mode will help you located similar issues.
    Best wishes
  • Thanks
    the problem is resolved
  • Hello
    I encounter a similar problem. Can you help me please.
    Best regards
    "D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\soft_micro\iar\stack\..\..\ble_sdk_2_02_01_18\
    tools/lib_search/lib_search.exe" D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\soft_micro\iar\
    stack/build_config.opt "D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\soft_micro\iar\stack\..\..\
    ble_sdk_2_02_01_18\tools/lib_search/params_split_cc2640.xml" D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial
    Module\soft_micro\iar\stack\..\..\ble_sdk_2_02_01_18\src/../blelib D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\
    Inertial Module\soft_micro\iar\stack/../config/lib_linker.cmd
    usage: LibSearch [-h] [-v] opt xml libdir cmd [config]
    LibSearch: error: unrecognized arguments: D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\soft_micro\iar\
    stack\..\..\ble_sdk_2_02_01_18\src/../blelib D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\soft_micro\
    Error while running "D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\soft_micro\iar\stack\..\..\
    ble_sdk_2_02_01_18\tools/lib_search/lib_search.exe" D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\
    soft_micro\iar\stack/build_config.opt "D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\Inertial Module\soft_micro\iar\
    stack\..\..\ble_sdk_2_02_01_18\tools/lib_search/params_split_cc2640.xml" D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation support\
    Inertial Module\soft_micro\iar\stack\..\..\ble_sdk_2_02_01_18\src/../blelib D:\Mes_Donnees_SO_GRICE\Travail\POC Prestation
    support\Inertial Module\soft_micro\iar\stack/../config/lib_linker.cmd
  • Try not to use white spaces in the paths, e.g., 'POC Prestation support'.
    Best wishes
