cc2640 100 osal_snv_read call within one minutes
Hi all, can i implement a logic that it call osal_snv_read 100 times with 1 minutes, and the logic may be run several time within one minutes, will it shorten the clip's life, thank you for your advice in advanced.
Should you use osal_snv_read as same as osal_snv_write, as I know osal_snv_write will shorten the life if I use usually.
