Other Parts Discussed in Thread: CC2640R2F,
Hello
I work with cc2650 sensortag. I want to programming this sensortag with OAD.
I use the document "Over-the-Air Download User’s Guide". My goal is not to use the flash externally.
Can you tell me the iar project to follow (project and project config) to work with sensortag without external flash (BIM + STACK + OAD Target App).
I test by following the indications of the document and I have the following message in "BLE Device Monitor" "A valid OAD header was not found in the image. Using generated header".
After you can tell me how to create an app compatible with the OAD.
Thanks for you help.
Best regards
