CC2650: NPI timing diagrams info needed
Part Number: CC2650
I am working on a NPI communication between a CC2650 chip and another one and I need an info about the timings. For example if the Slave initiates a transfer, the SRDY will be put low, after a certain delta t also the MRDY will be low and in the end for ending the transmission the MRDY will be put low, and in a certain amount of time also the SRDY will be low. So my question is what is the last delta t, between MRDY high and SRDY high, in my case it works with 1 ms, but I am wondering if there is an established timing for this.
Thank you very much in advance!
