RTOS/LAUNCHXL-CC2650: Discovering handles of server from multirole
Part Number: LAUNCHXL-CC2650
Tool/software: TI-RTOS
Hello I am working on Multirole project and spp_ble_server.
Stack : 2.2.1
I have the following attribute table in spp_ble_server
gattAttribute_t SerialPortServiceAttrTbl[SERVAPP_NUM_ATTR_SUPPORTED] =
   // Serial Port Profile Service
     { ATT_BT_UUID_SIZE, primaryServiceUUID }, /* type */
     GATT_PERMIT_READ,                         /* permissions */
     0,                                        /* handle */
     (uint8 *)&SerialPortService            /* pValue */
   // Characteristic Data Declaration
     { ATT_BT_UUID_SIZE, characterUUID },
     GATT_PERMIT_READ,
     0,
     &SerialPortServiceDataProps
   // Characteristic Data Value
     { ATT_UUID_SIZE, SerialPortServiceDataUUID },
     GATT_PERMIT_READ | GATT_PERMIT_WRITE,
     0,
   // Characteristic Data configuration
     { ATT_BT_UUID_SIZE, clientCharCfgUUID },
     0,
     (uint8 *)&SerialPortServiceDataConfig
   // Characteristic Data User Description
     { ATT_BT_UUID_SIZE, charUserDescUUID },
     GATT_PERMIT_READ,
     0,
     SerialPortServiceDataUserDesp
   // Characteristic Status Declaration
     GATT_PERMIT_READ,
     0,
     &SerialPortServiceStatusProps
   // Characteristic Status Value
     { ATT_UUID_SIZE, SerialPortServiceStatusUUID },
     GATT_PERMIT_READ,
     0,
     //&SerialPortServiceChar3
   // Characteristic Status configuration
     0,
     (uint8 *)&SerialPortServiceStatusConfig
   // Characteristic Status User Description
     GATT_PERMIT_READ,
     0,
     SerialPortServiceStatusUserDesp
And in the multirole side I discover serial port profile characteristic handle as shown below
       if (discInfo[connIndex].svcStartHdl != 0)
         attReadByTypeReq_t req;
         // Discover characteristic
         discInfo[connIndex].discState= BLE_DISC_STATE_CHAR;
         req.startHandle = discInfo[connIndex].svcStartHdl;
         req.endHandle = discInfo[connIndex].svcEndHdl;
         req.type.len = ATT_UUID_SIZE;
         // Discover characteristic descriptors
         GATT_DiscAllCharDescs(pMsg->connHandle,
                               req.startHandle + 1,
                               req.endHandle,
                               selfEntity);
  //if we're discovering characteristics
 else if (discInfo[connIndex].discState == BLE_DISC_STATE_CHAR)
   // Characteristic descriptors found
   if (pMsg->method == ATT_FIND_INFO_RSP &&
       pMsg->msg.findInfoRsp.numInfo > 0)
     uint8_t i;
     // For each handle/uuid pair
     for (i = 0; i < pMsg->msg.findInfoRsp.numInfo; i++)
       if(pMsg->msg.findInfoRsp.format == ATT_HANDLE_BT_UUID_TYPE)
         if ( (ATT_BT_PAIR_UUID(pMsg->msg.findInfoRsp.pInfo, i) ==
               GATT_CHARACTER_UUID))
           Display_print0(dispHandle, 0, 0, "GATT CHAR FOUND");
           Display_print1(dispHandle, 0, 0, "GATT CHAR HANDLE is %d" , ATT_PAIR_HANDLE(pMsg->msg.findInfoRsp.pInfo, i) );
           //StructHandles[connindexNum].charDeclHdl[charDeclIndex++] = ATT_PAIR_HANDLE(pMsg->msg.findInfoRsp.pInfo, i);
           break;
         // Look for CCCD
               GATT_CLIENT_CHAR_CFG_UUID))
           //Clear Flag
           //flags &= ~DATA_CHAR;
           Display_print0(dispHandle, 0, 0, "CFG FOUND");
           Display_print1(dispHandle, 0, 0, "CFG HANDLE is %d" , ATT_PAIR_HANDLE(pMsg->msg.findInfoRsp.pInfo, i) );
           StructHandles[connindexNum].charCCCDHdl[charCCCDindex++] = ATT_PAIR_HANDLE(pMsg->msg.findInfoRsp.pInfo, i);
           break;
       else if(pMsg->msg.findInfoRsp.format == ATT_HANDLE_UUID_TYPE)
         if (memcmp(&(pMsg->msg.findInfoRsp.pInfo[ATT_PAIR_UUID_IDX(i)]), uuidDataChar, ATT_UUID_SIZE) == 0)
           Display_print0(dispHandle, 0, 0, "Char 1 FOUND");
           charDataHdl[connindexNum1++] = ATT_PAIR_HANDLE(pMsg->msg.findInfoRsp.pInfo, i);
           StructHandles[connindexNum].charDeclHdl[charDeclIndex++] = ATT_PAIR_HANDLE(pMsg->msg.findInfoRsp.pInfo, i) - 1;
           //Set Flag
           //flags |= DATA_CHAR;
           break;
         if (memcmp(&(pMsg->msg.findInfoRsp.pInfo[ATT_PAIR_UUID_IDX(i)]), uuidDataCharStatus, ATT_UUID_SIZE) == 0)
           Display_print0(dispHandle, 0, 0, "Char 2 FOUND");
           //Set Flag
           break;
GATT_CHARACTER_UUID is Discovered only for first characteristic. Have I done anything wrong in the above method of discovering
the handles.
Output:
GATT CHAR FOUND
GATT CHAR HANDLE is 29
Char 1 FOUND
CFG  FOUND
CFG HANDLE is 31
Till here Everything is fine.
After this I expect
GATT CHAR FOUND
GATT CHAR HANDLE is 33
followed by
Char 2 FOUND
CFG  FOUND
CFG HANDLE is 35
But Software is not discovering GATT_CHARACTER_UUID. So the output is
Char 2 FOUND
CFG  FOUND
CFG HANDLE is 35
    Can you verify what is the value for req.endHandle? Can you hard code it to 65535 (max value) for testing?
    Also for next time, can you use rich formatting, the code is hard to read when double-spaced.
    Best wishes
