CC2640R2F: CC2640R2-SDK Documentation
Part Number: CC2640R2F
Dear Experts,
is there a PDF version of the different documents for the BLE-SDK-v3 (e.g. BLE SW Developer's Guide)? As far as I can see there is only HTML based documentation. In v2 it was PDF based.
Some people find it easier to search/navigate within a PDF. Would it be possible to add an option to either use the HTML or open as PDF version?
Thanks and best regards,
Rogerg
  • Hello Rogerg,
    Currently the CC2640R2 SDK documentation is provided in the web format which does have a search box. We are looking at making a PDF exported version available in a future SDK release.
    Best wishes
  • Hi JXS,
    yes, please consider to do so. The problems with the search box or benefits of a PDF version are:
    - searching within a PDF gives You all results in an overview with some context, so You already can determine if the search result is relevant or not
    - web-based search results in links without much of context, You then need to go to the links and search again or scroll through the document to find the highlighted search results
    BTW, I also noticed, that we do have references to CC13xx specific information (e.g. memory map) ...
    Many thanks and best regards,
    Rogerg
