Good day!
I'm trying to understand how to handle multiple BLE peripherals per central. I'm trying to create a sensor network of >10 temperature sensors, and I want to connect each sensor to my PC (central) using BLE. I also need the temperatures to be updated each second.
I've read that BLE only allows 7 peripherals connected to a central at the same time, but I don't think I need them all to be connected at the same time.
Possible scenario:
Sensor #1 connects to the central, transfers data and disconnects. When sensor #1 is done, sensor #2 goes through the same procedure by connecting, transferring and disconnecting. Then sensor #3 proceeds etc.
Do you know of any good way to make this happen? Maybe you know a better way to achieve the same result - to read >10 sensors in less than a second. Maybe BLE isn't what I should be using?
I'm truly greatful if you can help me, or point me in the right direction.
Best regards
Carl
