Other Parts Discussed in Thread: BLE-STACK, CC2640,
BLE-Stack V2.1 support SimpleEddystoneBeacon project, is it also support google nearby(Android beacon)?
Hello Erik,
I googled "Google Nearby" and found this FAQ page:
Which shows the following:
Nearby Notifications works in parallel with Eddystone-URL and Physical Web with the exact behavior depending on your use-cases and capabilities. For example, if you have one use-case that is available on your website, you might use an Eddystone-URL beacon. If the use-case is available in your app, you might use Nearby Notifications with an app intent.
So, you can use the Eddystone broadcast that CC2640 and CC2640R2F support to trigger Google Nearby on your Android device.
Best wishes
