RTOS/CC2650STK: Sending 2 Samples From Accelerometer data
Tool/software: TI-RTOS
Hi !
I'm using the Sensortag to send accelerometer data to my Pc and graph them on matlab, the comunication is established and everything works fine, I'm using the Sensor Tag code and I just send 6 bytes that are the x y z data from accelerometer, The sensor is sampling every 100 ms and send data every second.  It is suppoused that if I'm sampling at 100 ms I have 10 samples from the accelerometer, By now I just send 1 sample (6 bytes) every second, but what I would like to do is to send 2 samples (12 bytes ) every second to my pc ¿Does anyone have an idea of how to do it ?.
Another Q is that Do you know the part of the code that is the buffer where is stored the data  when sampling ?
Thank you for your response.
RH
