CC2564MODA: Flatness error on PCB
Part Number: CC2564MODA
Hi
Customer wants to know acceptable flatness error of customer PCB on CC2564MODA seating plane.
Is there any specification for this parameter ?
Background of the question:
Customer found a few boards on which CC2564MODA is soldered at a tilt.
Thanks and regards,
KoT
  • Hi Kot,
    IF the customer has soldered the module on a tilt, then there will be poor connection form the module to the customer PCB. You need to ensure that the voiding of the solder is no more than 30% on any pad and it should uniform across the module. My suggestion is to look at X-rays to see the voiding and to also look at the reflow provide and adjust as needed.
    Riz
