Part Number: CC2640R2F
Tool/software: TI-RTOS
This topic may have been discussed very long time ago but I don't see any fix or further discussion regarding this issue.
Based on the current CC2640R2F 1.35 SDK, this is how OAD handles the received writing block data:
- The central writes the block writing data to OAD_IMG_BLOCK_UUID
- oadWriteAttrCB() receives block data
- oadWriteAttrCB() sends the received data block to SimpleBLEPeripheral_processOadWriteCB()
- SimpleBLEPeripheral_processOadWriteCB() calls ICall_malloc() to get the memory from the heap and stores it to the heap
- The application task takes the data from the heap and save it to the flash
The problem is obvious. If the speed between Central and Peripheral is really fast. ICall_malloc() might run out of the heap memory if the flash writing takes a little bit more time. And I don't see the current SDK takes care of this situation.
Samson
