Part Number: CC2640R2F
Here below are what I have observed Off-Chip OAD failure when IAR Optimization set to High.
Scenario A:
- Set App optimization to None. Rebuild All BIM, App and Stack and Flash all 3 to CC2640R2 Launchpad.
- Create a OAD Image. Change Advertisement Name. Set App optimization to High. Rebuild All App to generate OAD Image bin file.
- Perform OAD using BTool. BTool OAD will start and finish successfully.
- Check Advertisement Name of CC2640R2 Launchpad if has change. Result is Advertisement Name is still the same and not changed. Meaning OAD was not successful.
Scenario B:
- Set App optimization to High. Rebuild All BIM, App and Stack and Flash all 3 to CC2640R2 Launchpad
- Perform OAD using BTool. OAD_FLASH_ERROR was returned. OAD did not start and not successful.
This is an issue for us because, if we do not set IAR optimization to High, the App will exceed the set flash space limit. Is there any way to make the OAD work with IAR optimization set to High?
- kel
