CCS/CC2650DK: ICall startup error while debugging BLE project zero stack: Target not run as the symbol "main" is not defined
Part Number: CC2650DK
Other Parts Discussed in Thread: CC2650
I am trying to resolve this icall_startup error in project_zero_stack_cc2650. While debugging the stack it gets suspended .I have attached a screenshot of ccs screen
    You should not see any startup errors with Project Zero (CC2650) if the build procedure is followed according to the directions. Please make sure you use TI Compiler v5.2.6. Also, the stack project is not debuggable since it's not executable.
    Best wishes
