CC2541: Error in accessing external variable
Part Number: CC2541
I am using the keyfob code on stack 1.4.2.2,have defined the variable in the simpleprofile.c  and i am trying to access the data in application code to read the value received from mobile app
when i trey to copy the received data from mobile app in simpleprofile_WriteAttrCB it shows error as Error[e46]:Undefined external.
i have tried the reverse way as well  that is declaring variable in application and accessing it in simpleprofile still the result was same. i am using IAR9.30,Evaluation version
once or twice it worked but after i rebuild the error started.
Please Suggest..!!!
Atul
