Tool/software: TI-RTOS
I have edited the simple_peripheral project of BLE_Stack_SDK as according to this guide till step 3 of 'Steps for out of box' section.But neither the characters typed from the terminal are echoed back to the terminal nor the simple_peripheral app is exposed(not showing in BLE Scanner application of my cell phone).
Here is the main function:-
int main()
#if defined( USE_FPGA )
HWREG(PRCM_BASE + PRCM_O_PDCTL0) &= ~PRCM_PDCTL0_RFC_ON;
HWREG(PRCM_BASE + PRCM_O_PDCTL1) &= ~PRCM_PDCTL1_RFC_ON;
#endif // USE_FPGA
/* Register Application callback to trap asserts raised in the Stack */
RegisterAssertCback(AssertHandler);
PIN_init(BoardGpioInitTable);
#ifdef CC1350_LAUNCHXL
// Enable 2.4GHz Radio
radCtrlHandle = PIN_open(&radCtrlState, radCtrlCfg);
#ifdef POWER_SAVING
Power_registerNotify(&rFSwitchPowerNotifyObj,
PowerCC26XX_ENTERING_STANDBY | PowerCC26XX_AWAKE_STANDBY,
(Power_NotifyFxn) rFSwitchNotifyCb, NULL);
#endif //POWER_SAVING
#endif //CC1350_LAUNCHXL
// set RFC mode to support BLE
// Note: This must be done before the RF Core is released from reset!
SET_RFC_BLE_MODE(RFC_MODE_BLE);
#endif // USE_FPGA
// Enable iCache prefetching
VIMSConfigure(VIMS_BASE, TRUE, TRUE);
// Enable cache
VIMSModeSet(VIMS_BASE, VIMS_MODE_ENABLED);
#if !defined( POWER_SAVING ) || defined( USE_FPGA )
/* Set constraints for Standby, powerdown and idle mode */
// PowerCC26XX_SB_DISALLOW may be redundant
Power_setConstraint(PowerCC26XX_SB_DISALLOW);
Power_setConstraint(PowerCC26XX_IDLE_PD_DISALLOW);
#endif // POWER_SAVING | USE_FPGA
/* Initialize ICall module */
ICall_init();
/* Start tasks of external images - Priority 5 */
ICall_createRemoteTasks();
/* Kick off profile - Priority 3 */
// priority changed to 2 for uart
GAPRole_createTask();
SimpleBLEPeripheral_createTask();
/* NPI UART Example Task - Priority 2 */
NPITask_createTask(2);
ti_sysbios_knl_Semaphore_Handle appSem = Semaphore_create(0, NULL, NULL);
/* enable interrupts and start SYS/BIOS */
BIOS_start();
return 0;
The main.c file is also attached herein for easy verification.
@file main.c
@brief main entry of the BLE stack sample application.
Group: WCS, BTS
Target Device: CC2650, CC2640, CC1350
Copyright (c) 2013-2016, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Release Name: ble_sdk_2_02_01_18
Release Date: 2016-10-26 15:20:04
* INCLUDES
#include <xdc/runtime/Error.h>
#include <ti/drivers/Power.h>
#include <ti/drivers/power/PowerCC26XX.h>
#include <ti/sysbios/BIOS.h>
#include "icall.h"
#include "hal_assert.h"
#include "bcomdef.h"
#include "peripheral.h"
#include "simple_peripheral.h"
/* Header files required to enable instruction fetch cache */
#include <inc/hw_memmap.h>
#include <driverlib/vims.h>
#ifndef USE_DEFAULT_USER_CFG
#include "ble_user_config.h"
// BLE user defined configuration
bleUserCfg_t user0Cfg = BLE_USER_CFG;
#endif // USE_DEFAULT_USER_CFG
#include <ti/mw/display/Display.h>
#ifdef USE_FPGA
#include <inc/hw_prcm.h>
#endif // USE_FPGA
#include "npi_task.h"
* MACROS
* CONSTANTS
#define RFC_MODE_BLE PRCM_RFCMODESEL_CURR_MODE1
#define RFC_MODE_ANT PRCM_RFCMODESEL_CURR_MODE4
#define RFC_MODE_EVERYTHING_BUT_ANT PRCM_RFCMODESEL_CURR_MODE5
#define RFC_MODE_EVERYTHING PRCM_RFCMODESEL_CURR_MODE6
#define SET_RFC_BLE_MODE(mode) HWREG( PRCM_BASE + PRCM_O_RFCMODESEL ) = (mode)
#endif // USE_FPGA
* TYPEDEFS
* LOCAL VARIABLES
* GLOBAL VARIABLES
#ifdef POWER_SAVING
// Power Notify Object for wake-up callbacks
Power_NotifyObj rFSwitchPowerNotifyObj;
static uint8_t rFSwitchNotifyCb(uint8_t eventType, uint32_t *eventArg,
uint32_t *clientArg);
PIN_State radCtrlState;
PIN_Config radCtrlCfg[] =
Board_DIO1_RFSW | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* RF SW Switch defaults to 2.4GHz path*/
Board_DIO30_SWPWR | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* Power to the RF Switch */
PIN_TERMINATE
PIN_Handle radCtrlHandle;
* EXTERNS
extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
extern Display_Handle dispHandle;
* @fn Main
* @brief Application Main
* input parameters
* @param None.
* output parameters
* @param None.
* @return None.
int main()
#endif // USE_FPGA
#ifdef POWER_SAVING
#endif // USE_FPGA
// Enable cache
ICall_init();
BIOS_start();
return 0;
* @fn AssertHandler
* @brief This is the Application's callback handler for asserts raised
* in the stack. When EXT_HAL_ASSERT is defined in the Stack
* project this function will be called when an assert is raised,
* and can be used to observe or trap a violation from expected
* behavior.
* As an example, for Heap allocation failures the Stack will raise
* HAL_ASSERT_CAUSE_OUT_OF_MEMORY as the assertCause and
* HAL_ASSERT_SUBCAUSE_NONE as the assertSubcause. An application
* developer could trap any malloc failure on the stack by calling
* HAL_ASSERT_SPINLOCK under the matching case.
* An application developer is encouraged to extend this function
* for use by their own application. To do this, add hal_assert.c
* to your project workspace, the path to hal_assert.h (this can
* be found on the stack side). Asserts are raised by including
* hal_assert.h and using macro HAL_ASSERT(cause) to raise an
* assert with argument assertCause. the assertSubcause may be
* optionally set by macro HAL_ASSERT_SET_SUBCAUSE(subCause) prior
* to asserting the cause it describes. More information is
* available in hal_assert.h.
* input parameters
* @param assertCause - Assert cause as defined in hal_assert.h.
* @param assertSubcause - Optional assert subcause (see hal_assert.h).
* output parameters
* @param None.
* @return None.
// Open the display if the app has not already done so
if ( !dispHandle )
dispHandle = Display_open(Display_Type_LCD, NULL);
Display_print0(dispHandle, 0, 0, ">>>STACK ASSERT");
// check the assert cause
switch (assertCause)
case HAL_ASSERT_CAUSE_OUT_OF_MEMORY:
Display_print0(dispHandle, 0, 0, "***ERROR***");
Display_print0(dispHandle, 2, 0, ">> OUT OF MEMORY!");
break;
case HAL_ASSERT_CAUSE_INTERNAL_ERROR:
// check the subcause
if (assertSubcause == HAL_ASSERT_SUBCAUSE_FW_INERNAL_ERROR)
Display_print0(dispHandle, 2, 0, ">> INTERNAL FW ERROR!");
else
Display_print0(dispHandle, 2, 0, ">> INTERNAL ERROR!");
break;
case HAL_ASSERT_CAUSE_ICALL_ABORT:
Display_print0(dispHandle, 2, 0, ">> ICALL ABORT!");
HAL_ASSERT_SPINLOCK;
break;
default:
Display_print0(dispHandle, 2, 0, ">> DEFAULT SPINLOCK!");
return;
* @fn smallErrorHook
* @brief Error handler to be hooked into TI-RTOS.
* input parameters
* @param eb - Pointer to Error Block.
* output parameters
* @param None.
* @return None.
void smallErrorHook(Error_Block *eb)
for (;;);
#if defined (CC1350_LAUNCHXL) && defined (POWER_SAVING)
* @fn rFSwitchNotifyCb
* @brief Power driver callback to toggle RF switch on Power state
* transitions.
* input parameters
* @param eventType - The state change.
* @param eventArg - Not used.
* @param clientArg - Not used.
* @return Power_NOTIFYDONE to indicate success.
if (eventType == PowerCC26XX_ENTERING_STANDBY)
// Power down RF Switch
PIN_setOutputValue(radCtrlHandle, Board_DIO30_SWPWR, 0);
else if (eventType == PowerCC26XX_AWAKE_STANDBY)
// Power up RF Switch
PIN_setOutputValue(radCtrlHandle, Board_DIO30_SWPWR, 1);
// Notification handled successfully
return Power_NOTIFYDONE;
#endif //CC1350_LAUNCHXL || POWER_SAVING
Thanks in advance.
Arunava.
Note:-
1) I found this too and had gone through it for better understanding.
2) I'm using ZOC7 as the terminal emulator.
