Other Parts Discussed in Thread: CC2650STK, CC2640, BLE-STACK
my Development environment is CCS 7.3.0.00019 with BLE Stack 2.2.1 and Compiler TI v5.2.6. My device is a Simplelink Sensor TAG (CC2650STK) Rev.1.3.
When I flash the pre-build firmware from the BLE Stack (file cc2650stk_sensortag_rel.hex located in ..\ti\simplelink\ble_sdk_2_02_01_18\examples\hex), the CC2650STK goes in stand by after 3 min. The stand by current settles down between 4 - 8 uA.
When I build the firmware from source:
- ..\ti\simplelink\ble_sdk_2_02_01_18\examples\cc2650stk\sensortag\ccs\app
- ..\ti\simplelink\ble_sdk_2_02_01_18\examples\cc2650stk\sensortag\ccs\stack
- ..\ti\simplelink\ble_sdk_2_02_01_18\examples\util\bim_extflash\cc2640\ccs
the CC2650STK goes also in stand by, but the stand by current settles down between 176 - 180 uA.
I use the source code and configuration from TI without any changes. Can you please explain the difference between source where the pre-build hex file is based on and the source code from the BLE Stack 2.2.1.
I have read hundreds of posts but I found no solution. I hope you can help.
