Part Number: CC2640
Other Parts Discussed in Thread: CC2540, BLE-STACK
We’ve been having some difficulties performing an OAD with our CC2640 device using the SensorTag Android app at www.ti.com/.../SENSORTAG-SW. We have also observed these issues when using BLE Device Monitor with CC2540Dongle.
The primary issue we’ve been encountering is that the download will occasionally take an excessive amount of time. Normally, a download operation with the app takes approximately 3 minutes. However, this will occasionally take 80 minutes. I’ve attached two log files from such runs. These were obtained via logcat and processed for clarity. The app estimated that the longer download operation would complete in 5100s, but I cancelled it after approximately 300s.
I’ve been working with the assumption that the issue is primarily on the application’s side. However, it appears that the app doesn’t receive a block request notification from the CC2640 until around 2 seconds after the app wrote previous block during the slower downloads. An example is below:
11-07 16:10:35.050 Notify UUID f000ffc2-0451-4000-b000-000000000000
11-07 16:10:35.051 Notify data AC:00
11-07 16:10:35.093 Write UUID f000ffc2-0451-4000-b000-000000000000
11-07 16:10:35.094 Write data AC:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX
11-07 16:10:37.045 Notify UUID f000ffc2-0451-4000-b000-000000000000
11-07 16:10:37.045 Notify data AD:00
11-07 16:10:37.087 Write UUID f000ffc2-0451-4000-b000-000000000000
11-07 16:10:37.089 Write data AD:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX
11-07 16:10:39.040 Notify UUID f000ffc2-0451-4000-b000-000000000000
11-07 16:10:39.040 Notify data AE:00
11-07 16:10:39.082 Write UUID f000ffc2-0451-4000-b000-000000000000
11-07 16:10:39.083 Write data AE:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX
This delay was much shorter in the faster download operations, being around 30ms to 40ms on average.
Our hardware is a CC2640 using SDK 2.1. We discovered a short while ago that we had misconfigured our first run of hardware, and had the firmware configured to be differential when we were only using a single-ended antenna.
Some of this product is already on the market. We would like to find the most user-friendly way to accomplish an OAD in this case, and to ensure that future products do not suffer this way.
11-07 16:04:40.984 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:40.986 Write data 0D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:42.936 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:42.936 Notify data 0E:00 11-07 16:04:42.977 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:42.979 Write data 0E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:45.929 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:45.929 Notify data 0F:00 11-07 16:04:45.971 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:45.972 Write data 0F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:47.923 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:47.924 Notify data 10:00 11-07 16:04:47.966 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:47.967 Write data 10:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:49.918 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:49.919 Notify data 11:00 11-07 16:04:49.960 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:49.962 Write data 11:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:51.913 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:51.914 Notify data 12:00 11-07 16:04:51.955 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:51.957 Write data 12:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:54.906 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:54.906 Notify data 13:00 11-07 16:04:54.947 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:54.949 Write data 13:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:56.901 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:56.901 Notify data 14:00 11-07 16:04:56.943 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:56.945 Write data 14:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:04:59.893 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:59.894 Notify data 15:00 11-07 16:04:59.936 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:04:59.937 Write data 15:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:01.888 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:01.889 Notify data 16:00 11-07 16:05:01.930 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:01.932 Write data 16:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:03.883 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:03.884 Notify data 17:00 11-07 16:05:03.934 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:03.935 Write data 17:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:05.878 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:05.878 Notify data 18:00 11-07 16:05:05.920 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:05.922 Write data 18:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:07.873 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:07.874 Notify data 19:00 11-07 16:05:07.915 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:07.917 Write data 19:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:09.869 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:09.869 Notify data 1A:00 11-07 16:05:09.910 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:09.912 Write data 1A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:11.863 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:11.864 Notify data 1B:00 11-07 16:05:11.905 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:11.907 Write data 1B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:14.856 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:14.856 Notify data 1C:00 11-07 16:05:14.898 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:14.900 Write data 1C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:16.851 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:16.851 Notify data 1D:00 11-07 16:05:16.893 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:16.895 Write data 1D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:18.846 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:18.846 Notify data 1E:00 11-07 16:05:18.888 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:18.890 Write data 1E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:20.841 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:20.841 Notify data 1F:00 11-07 16:05:20.883 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:20.885 Write data 1F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:22.836 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:22.836 Notify data 20:00 11-07 16:05:22.878 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:22.880 Write data 20:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:24.830 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:24.831 Notify data 21:00 11-07 16:05:24.872 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:24.874 Write data 21:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:26.826 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:26.826 Notify data 22:00 11-07 16:05:26.867 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:26.869 Write data 22:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:29.818 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:29.819 Notify data 23:00 11-07 16:05:29.860 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:29.862 Write data 23:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:31.813 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:31.814 Notify data 24:00 11-07 16:05:31.855 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:31.857 Write data 24:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:33.808 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:33.809 Notify data 25:00 11-07 16:05:33.850 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:33.852 Write data 25:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:35.803 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:35.804 Notify data 26:00 11-07 16:05:35.845 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:35.846 Write data 26:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:37.798 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:37.799 Notify data 27:00 11-07 16:05:37.840 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:37.841 Write data 27:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:40.790 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:40.791 Notify data 28:00 11-07 16:05:40.833 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:40.835 Write data 28:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:42.785 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:42.786 Notify data 29:00 11-07 16:05:42.827 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:42.829 Write data 29:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:44.781 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:44.781 Notify data 2A:00 11-07 16:05:44.823 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:44.824 Write data 2A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:46.775 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:46.776 Notify data 2B:00 11-07 16:05:46.817 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:46.819 Write data 2B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:49.768 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:49.768 Notify data 2C:00 11-07 16:05:49.810 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:49.812 Write data 2C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:51.763 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:51.764 Notify data 2D:00 11-07 16:05:51.805 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:51.807 Write data 2D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:53.758 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:53.758 Notify data 2E:00 11-07 16:05:53.801 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:53.803 Write data 2E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:55.753 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:55.754 Notify data 2F:00 11-07 16:05:55.795 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:55.797 Write data 2F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:57.748 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:57.748 Notify data 30:00 11-07 16:05:57.790 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:57.792 Write data 30:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:05:59.743 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:59.743 Notify data 31:00 11-07 16:05:59.785 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:05:59.786 Write data 31:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:01.738 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:01.739 Notify data 32:00 11-07 16:06:01.780 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:01.782 Write data 32:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:03.733 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:03.733 Notify data 33:00 11-07 16:06:03.776 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:03.778 Write data 33:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:05.728 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:05.728 Notify data 34:00 11-07 16:06:05.770 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:05.771 Write data 34:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:07.723 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:07.723 Notify data 35:00 11-07 16:06:07.764 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:07.766 Write data 35:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:09.718 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:09.718 Notify data 36:00 11-07 16:06:09.759 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:09.761 Write data 36:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:11.713 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:11.714 Notify data 37:00 11-07 16:06:11.756 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:11.757 Write data 37:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:14.705 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:14.705 Notify data 38:00 11-07 16:06:14.747 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:14.749 Write data 38:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:16.700 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:16.700 Notify data 39:00 11-07 16:06:16.742 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:16.743 Write data 39:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:19.693 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:19.693 Notify data 3A:00 11-07 16:06:19.735 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:19.736 Write data 3A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:21.687 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:21.688 Notify data 3B:00 11-07 16:06:21.729 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:21.731 Write data 3B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:23.682 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:23.682 Notify data 3C:00 11-07 16:06:23.725 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:23.726 Write data 3C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:25.677 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:25.678 Notify data 3D:00 11-07 16:06:25.720 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:25.721 Write data 3D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:27.673 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:27.673 Notify data 3E:00 11-07 16:06:27.715 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:27.716 Write data 3E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:30.665 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:30.665 Notify data 3F:00 11-07 16:06:30.707 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:30.709 Write data 3F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:33.658 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:33.658 Notify data 40:00 11-07 16:06:33.699 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:33.701 Write data 40:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:35.653 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:35.653 Notify data 41:00 11-07 16:06:35.695 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:35.697 Write data 41:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:37.647 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:37.648 Notify data 42:00 11-07 16:06:37.690 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:37.691 Write data 42:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:39.642 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:39.643 Notify data 43:00 11-07 16:06:39.684 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:39.686 Write data 43:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:41.637 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:41.638 Notify data 44:00 11-07 16:06:41.680 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:41.682 Write data 44:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:43.632 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:43.632 Notify data 45:00 11-07 16:06:43.683 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:43.685 Write data 45:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:45.627 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:45.627 Notify data 46:00 11-07 16:06:45.669 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:45.672 Write data 46:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:48.620 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:48.620 Notify data 47:00 11-07 16:06:48.661 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:48.663 Write data 47:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:50.615 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:50.615 Notify data 48:00 11-07 16:06:50.656 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:50.658 Write data 48:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:52.610 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:52.610 Notify data 49:00 11-07 16:06:52.653 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:52.654 Write data 49:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:54.605 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:54.605 Notify data 4A:00 11-07 16:06:54.647 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:54.649 Write data 4A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:06:56.600 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:56.600 Notify data 4B:00 11-07 16:06:56.641 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:06:56.643 Write data 4B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:00.589 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:00.590 Notify data 4C:00 11-07 16:07:00.631 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:00.633 Write data 4C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:02.585 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:02.585 Notify data 4D:00 11-07 16:07:02.627 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:02.628 Write data 4D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:04.580 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:04.580 Notify data 4E:00 11-07 16:07:04.622 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:04.624 Write data 4E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:06.575 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:06.575 Notify data 4F:00 11-07 16:07:06.617 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:06.619 Write data 4F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:08.570 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:08.570 Notify data 50:00 11-07 16:07:08.612 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:08.613 Write data 50:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:10.564 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:10.565 Notify data 51:00 11-07 16:07:10.606 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:10.608 Write data 51:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:12.559 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:12.560 Notify data 52:00 11-07 16:07:12.601 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:12.603 Write data 52:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:15.552 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:15.552 Notify data 53:00 11-07 16:07:15.594 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:15.596 Write data 53:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:17.547 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:17.547 Notify data 54:00 11-07 16:07:17.589 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:17.591 Write data 54:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:19.542 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:19.543 Notify data 55:00 11-07 16:07:19.584 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:19.586 Write data 55:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:21.538 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:21.538 Notify data 56:00 11-07 16:07:21.580 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:21.581 Write data 56:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:23.532 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:23.532 Notify data 57:00 11-07 16:07:23.574 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:23.576 Write data 57:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:25.527 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:25.527 Notify data 58:00 11-07 16:07:25.569 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:25.570 Write data 58:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:27.522 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:27.522 Notify data 59:00 11-07 16:07:27.563 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:27.565 Write data 59:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:30.514 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:30.514 Notify data 5A:00 11-07 16:07:30.556 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:30.558 Write data 5A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:32.509 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:32.510 Notify data 5B:00 11-07 16:07:32.551 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:32.552 Write data 5B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:34.504 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:34.505 Notify data 5C:00 11-07 16:07:34.550 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:34.552 Write data 5C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:36.499 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:36.500 Notify data 5D:00 11-07 16:07:36.541 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:36.543 Write data 5D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:38.494 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:38.495 Notify data 5E:00 11-07 16:07:38.537 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:38.539 Write data 5E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:40.489 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:40.490 Notify data 5F:00 11-07 16:07:40.531 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:40.533 Write data 5F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:42.484 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:42.485 Notify data 60:00 11-07 16:07:42.526 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:42.528 Write data 60:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:44.480 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:44.480 Notify data 61:00 11-07 16:07:44.521 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:44.523 Write data 61:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:47.472 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:47.472 Notify data 62:00 11-07 16:07:47.513 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:47.514 Write data 62:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:49.467 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:49.467 Notify data 63:00 11-07 16:07:49.517 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:49.519 Write data 63:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:51.462 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:51.462 Notify data 64:00 11-07 16:07:51.503 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:51.505 Write data 64:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:53.457 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:53.457 Notify data 65:00 11-07 16:07:53.497 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:53.499 Write data 65:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:55.452 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:55.452 Notify data 66:00 11-07 16:07:55.493 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:55.495 Write data 66:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:07:59.442 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:59.442 Notify data 67:00 11-07 16:07:59.483 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:07:59.484 Write data 67:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:01.437 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:01.437 Notify data 68:00 11-07 16:08:01.478 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:01.480 Write data 68:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:03.432 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:03.432 Notify data 69:00 11-07 16:08:03.474 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:03.476 Write data 69:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:05.426 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:05.427 Notify data 6A:00 11-07 16:08:05.468 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:05.469 Write data 6A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:07.421 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:07.422 Notify data 6B:00 11-07 16:08:07.463 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:07.465 Write data 6B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:09.417 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:09.417 Notify data 6C:00 11-07 16:08:09.461 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:09.463 Write data 6C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:11.412 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:11.412 Notify data 6D:00 11-07 16:08:11.453 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:11.455 Write data 6D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:13.406 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:13.407 Notify data 6E:00 11-07 16:08:13.449 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:13.451 Write data 6E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:15.402 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:15.402 Notify data 6F:00 11-07 16:08:15.443 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:15.445 Write data 6F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:18.394 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:18.395 Notify data 70:00 11-07 16:08:18.436 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:18.438 Write data 70:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:20.389 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:20.390 Notify data 71:00 11-07 16:08:20.431 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:20.433 Write data 71:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:22.384 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:22.384 Notify data 72:00 11-07 16:08:22.426 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:22.428 Write data 72:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:24.379 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:24.379 Notify data 73:00 11-07 16:08:24.429 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:24.431 Write data 73:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:26.374 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:26.374 Notify data 74:00 11-07 16:08:26.416 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:26.417 Write data 74:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:29.367 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:29.367 Notify data 75:00 11-07 16:08:29.408 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:29.410 Write data 75:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:31.361 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:31.362 Notify data 76:00 11-07 16:08:31.403 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:31.405 Write data 76:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:33.357 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:33.357 Notify data 77:00 11-07 16:08:33.398 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:33.400 Write data 77:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:36.348 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:36.349 Notify data 78:00 11-07 16:08:36.391 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:36.393 Write data 78:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:38.344 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:38.344 Notify data 79:00 11-07 16:08:38.386 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:38.387 Write data 79:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:40.339 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:40.339 Notify data 7A:00 11-07 16:08:40.380 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:40.381 Write data 7A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:42.334 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:42.334 Notify data 7B:00 11-07 16:08:42.375 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:42.377 Write data 7B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:44.329 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:44.329 Notify data 7C:00 11-07 16:08:44.370 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:44.372 Write data 7C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:46.323 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:46.324 Notify data 7D:00 11-07 16:08:46.364 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:46.366 Write data 7D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:48.319 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:48.320 Notify data 7E:00 11-07 16:08:48.360 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:48.362 Write data 7E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:50.314 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:50.314 Notify data 7F:00 11-07 16:08:50.355 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:50.357 Write data 7F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:52.309 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:52.309 Notify data 80:00 11-07 16:08:52.350 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:52.352 Write data 80:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:55.301 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:55.302 Notify data 81:00 11-07 16:08:55.343 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:55.345 Write data 81:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:08:58.294 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:58.294 Notify data 82:00 11-07 16:08:58.335 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:08:58.337 Write data 82:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:00.289 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:00.289 Notify data 83:00 11-07 16:09:00.330 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:00.332 Write data 83:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:02.283 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:02.284 Notify data 84:00 11-07 16:09:02.325 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:02.327 Write data 84:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:06.274 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:06.274 Notify data 85:00 11-07 16:09:06.316 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:06.317 Write data 85:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:08.268 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:08.269 Notify data 86:00 11-07 16:09:08.310 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:08.312 Write data 86:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:10.264 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:10.264 Notify data 87:00 11-07 16:09:10.305 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:10.307 Write data 87:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:12.259 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:12.259 Notify data 88:00 11-07 16:09:12.302 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:12.303 Write data 88:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:14.254 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:14.254 Notify data 89:00 11-07 16:09:14.296 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:14.297 Write data 89:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:16.249 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:16.249 Notify data 8A:00 11-07 16:09:16.300 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:16.302 Write data 8A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:18.244 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:18.244 Notify data 8B:00 11-07 16:09:18.286 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:18.287 Write data 8B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:21.236 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:21.236 Notify data 8C:00 11-07 16:09:21.278 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:21.280 Write data 8C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:23.231 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:23.231 Notify data 8D:00 11-07 16:09:23.273 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:23.274 Write data 8D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:26.223 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:26.224 Notify data 8E:00 11-07 16:09:26.264 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:26.266 Write data 8E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:28.219 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:28.219 Notify data 8F:00 11-07 16:09:28.261 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:28.262 Write data 8F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:30.213 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:30.214 Notify data 90:00 11-07 16:09:30.255 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:30.257 Write data 90:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:32.208 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:32.208 Notify data 91:00 11-07 16:09:32.250 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:32.252 Write data 91:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:34.203 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:34.203 Notify data 92:00 11-07 16:09:34.245 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:34.247 Write data 92:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:36.199 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:36.199 Notify data 93:00 11-07 16:09:36.240 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:36.242 Write data 93:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:39.191 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:39.191 Notify data 94:00 11-07 16:09:39.232 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:39.234 Write data 94:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:41.186 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:41.186 Notify data 95:00 11-07 16:09:41.227 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:41.228 Write data 95:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:43.181 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:43.181 Notify data 96:00 11-07 16:09:43.224 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:43.226 Write data 96:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:45.176 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:45.176 Notify data 97:00 11-07 16:09:45.217 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:45.219 Write data 97:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:47.171 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:47.171 Notify data 98:00 11-07 16:09:47.212 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:47.214 Write data 98:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:49.166 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:49.166 Notify data 99:00 11-07 16:09:49.207 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:49.209 Write data 99:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:52.158 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:52.158 Notify data 9A:00 11-07 16:09:52.200 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:52.202 Write data 9A:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:54.153 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:54.153 Notify data 9B:00 11-07 16:09:54.195 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:54.197 Write data 9B:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:56.148 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:56.148 Notify data 9C:00 11-07 16:09:56.190 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:56.192 Write data 9C:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:09:58.144 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:58.144 Notify data 9D:00 11-07 16:09:58.185 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:09:58.186 Write data 9D:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:00.138 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:00.138 Notify data 9E:00 11-07 16:10:00.179 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:00.180 Write data 9E:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:04.128 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:04.129 Notify data 9F:00 11-07 16:10:04.170 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:04.171 Write data 9F:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:06.123 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:06.123 Notify data A0:00 11-07 16:10:06.164 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:06.166 Write data A0:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:08.118 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:08.118 Notify data A1:00 11-07 16:10:08.166 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:08.168 Write data A1:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:11.111 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:11.111 Notify data A2:00 11-07 16:10:11.153 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:11.155 Write data A2:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:13.105 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:13.106 Notify data A3:00 11-07 16:10:13.147 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:13.148 Write data A3:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:15.100 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:15.100 Notify data A4:00 11-07 16:10:15.142 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:15.144 Write data A4:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:17.095 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:17.095 Notify data A5:00 11-07 16:10:17.137 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:17.138 Write data A5:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:21.086 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:21.086 Notify data A6:00 11-07 16:10:21.127 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:21.129 Write data A6:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:23.080 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:23.081 Notify data A7:00 11-07 16:10:23.123 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:23.124 Write data A7:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:25.075 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:25.076 Notify data A8:00 11-07 16:10:25.117 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:25.118 Write data A8:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:27.070 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:27.071 Notify data A9:00 11-07 16:10:27.112 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:27.114 Write data A9:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:30.063 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:30.063 Notify data AA:00 11-07 16:10:30.104 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:30.106 Write data AA:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:33.056 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:33.056 Notify data AB:00 11-07 16:10:33.098 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:33.099 Write data AB:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:35.050 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:35.051 Notify data AC:00 11-07 16:10:35.093 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:35.094 Write data AC:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:37.045 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:37.045 Notify data AD:00 11-07 16:10:37.087 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:37.089 Write data AD:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:39.040 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:39.040 Notify data AE:00 11-07 16:10:39.082 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:39.083 Write data AE:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:41.036 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:41.036 Notify data AF:00 11-07 16:10:41.077 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:41.079 Write data AF:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:43.029 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:43.030 Notify data B0:00 11-07 16:10:43.070 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:43.072 Write data B0:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:45.025 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:45.025 Notify data B1:00 11-07 16:10:45.066 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:45.068 Write data B1:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:47.020 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:47.020 Notify data B2:00 11-07 16:10:47.062 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:47.064 Write data B2:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:49.015 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:49.015 Notify data B3:00 11-07 16:10:49.055 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:49.057 Write data B3:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:51.010 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:51.011 Notify data B4:00 11-07 16:10:51.052 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:51.054 Write data B4:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:53.005 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:53.005 Notify data B5:00 11-07 16:10:53.047 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:53.049 Write data B5:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:55.000 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:55.001 Notify data B6:00 11-07 16:10:55.042 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:55.044 Write data B6:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:56.995 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:56.996 Notify data B7:00 11-07 16:10:57.037 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:57.039 Write data B7:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:10:58.990 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:58.990 Notify data B8:00 11-07 16:10:59.035 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:10:59.036 Write data B8:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:02.980 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:02.980 Notify data B9:00 11-07 16:11:03.021 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:03.022 Write data B9:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:04.975 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:04.975 Notify data BA:00 11-07 16:11:05.017 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:05.019 Write data BA:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:06.970 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:06.970 Notify data BB:00 11-07 16:11:07.011 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:07.013 Write data BB:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:08.966 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:08.966 Notify data BC:00 11-07 16:11:09.008 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:09.010 Write data BC:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:10.960 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:10.960 Notify data BD:00 11-07 16:11:11.001 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:11.003 Write data BD:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:12.955 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:12.955 Notify data BE:00 11-07 16:11:12.996 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:12.998 Write data BE:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:15.948 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:15.948 Notify data BF:00 11-07 16:11:15.989 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:15.991 Write data BF:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:17.943 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:17.943 Notify data C0:00 11-07 16:11:17.985 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:17.987 Write data C0:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:19.937 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:19.938 Notify data C1:00 11-07 16:11:19.978 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:19.980 Write data C1:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:21.932 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:21.933 Notify data C2:00 11-07 16:11:21.974 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:21.976 Write data C2:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:24.925 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:24.925 Notify data C3:00 11-07 16:11:24.966 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:24.968 Write data C3:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:26.920 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:26.920 Notify data C4:00 11-07 16:11:26.961 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:26.963 Write data C4:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:28.914 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:28.915 Notify data C5:00 11-07 16:11:28.957 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:28.959 Write data C5:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:31.907 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:31.908 Notify data C6:00 11-07 16:11:31.949 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:31.951 Write data C6:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:33.902 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:33.903 Notify data C7:00 11-07 16:11:33.950 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:33.953 Write data C7:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:35.897 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:35.897 Notify data C8:00 11-07 16:11:35.938 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:35.940 Write data C8:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:37.892 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:37.892 Notify data C9:00 11-07 16:11:37.934 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:37.936 Write data C9:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:39.887 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:39.888 Notify data CA:00 11-07 16:11:39.929 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:39.930 Write data CA:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:43.877 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:43.877 Notify data CB:00 11-07 16:11:43.919 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:43.920 Write data CB:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:46.870 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:46.870 Notify data CC:00 11-07 16:11:46.911 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:46.913 Write data CC:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:48.864 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:48.864 Notify data CD:00 11-07 16:11:48.906 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:48.907 Write data CD:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:50.859 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:50.860 Notify data CE:00 11-07 16:11:50.901 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:50.903 Write data CE:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:52.855 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:52.855 Notify data CF:00 11-07 16:11:52.900 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:52.902 Write data CF:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:54.849 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:54.850 Notify data D0:00 11-07 16:11:54.891 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:54.893 Write data D0:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:11:57.841 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:57.842 Notify data D1:00 11-07 16:11:57.882 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:11:57.884 Write data D1:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:00.834 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:00.835 Notify data D2:00 11-07 16:12:00.876 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:00.878 Write data D2:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:02.829 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:02.830 Notify data D3:00 11-07 16:12:02.871 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:02.872 Write data D3:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:04.825 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:04.825 Notify data D4:00 11-07 16:12:04.866 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:04.868 Write data D4:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:06.819 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:06.820 Notify data D5:00 11-07 16:12:06.860 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:06.862 Write data D5:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:08.814 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:08.815 Notify data D6:00 11-07 16:12:08.856 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:08.857 Write data D6:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:10.809 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:10.810 Notify data D7:00 11-07 16:12:10.851 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:10.853 Write data D7:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:12.804 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:12.804 Notify data D8:00 11-07 16:12:12.846 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:12.847 Write data D8:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:14.800 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:14.800 Notify data D9:00 11-07 16:12:14.842 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:14.843 Write data D9:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:16.794 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:16.794 Notify data DA:00 11-07 16:12:16.836 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:16.837 Write data DA:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:18.789 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:18.790 Notify data DB:00 11-07 16:12:18.830 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:18.832 Write data DB:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:20.784 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:20.784 Notify data DC:00 11-07 16:12:20.825 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:20.827 Write data DC:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:22.779 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:22.779 Notify data DD:00 11-07 16:12:22.821 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:22.823 Write data DD:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:24.774 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:24.775 Notify data DE:00 11-07 16:12:24.816 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:24.818 Write data DE:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX 11-07 16:12:26.769 Notify UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:26.769 Notify data DF:00 11-07 16:12:26.811 Write UUID f000ffc2-0451-4000-b000-000000000000 11-07 16:12:26.813 Write data DF:00:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX
