CCS/cc2650: Facing error in interfacing I2C sensor with CC2650MODA
Part Number: CC2650
Other Parts Discussed in Thread: CC2650, CC2650MODA, CC2650STK
I am trying to interface Arduino with CC2650 MODA.
For that I have refred Application Report - SWRA534A atached below
Application_Note.pdf
With this changes, It is working fine for CC2650 Sensortag and I am able to get data on mobile app.
But when I upload same code on CC2650MODA, I amd not getting data on Mobile app. I am getting only Key events on mobile app.
Please find attached screenshoot for same.
Can anyone please guide me, what is problem here ?
Following are updated Board files.
0743.Board.h
 * Copyright (c) 2015-2016, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ====================== CC2650STK.c =========================================
 *  This file is responsible for setting up the board specific items for the
 *  CC2650 SensorTag.
 *  ====================== Includes ============================================
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/family/arm/m3/Hwi.h>
#include <ti/drivers/PIN.h>
#include <ti/drivers/pin/PINCC26XX.h>
#include <ti/drivers/Power.h>
#include <ti/drivers/power/PowerCC26XX.h>
#include <inc/hw_memmap.h>
#include <inc/hw_ints.h>
#include <driverlib/ioc.h>
#include <driverlib/udma.h>
#include "Board.h"
 *  ========================= IO driver initialization =========================
 *  From main, PIN_init(BoardGpioInitTable) should be called to setup safe
 *  settings for this board.
 *  When a pin is allocated and then de-allocated, it will revert to the state
 *  configured in this table.
/* Place into subsections to allow the TI linker to remove items properly */
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_SECTION(BoardGpioInitTable, ".const:BoardGpioInitTable")
#pragma DATA_SECTION(PINCC26XX_hwAttrs, ".const:PINCC26XX_hwAttrs")
#endif
const PIN_Config BoardGpioInitTable[] = {
  /*  Board_STK_LED1   | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    Board_STK_LED2   | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    Board_KEY_LEFT   | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,
    Board_KEY_RIGHT  | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,
    Board_RELAY      | PIN_INPUT_EN | PIN_PULLDOWN | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,
    Board_MPU_INT    | PIN_INPUT_EN | PIN_PULLDOWN | PIN_IRQ_NEGEDGE | PIN_HYSTERESIS,
    Board_TMP_RDY    | PIN_INPUT_EN | PIN_PULLUP | PIN_HYSTERESIS,
    Board_BUZZER     | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    Board_MPU_POWER  | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    Board_MIC_POWER  | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MIN,
    Board_SPI_FLASH_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MIN,
    Board_SPI_DEVPK_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MIN,
    Board_AUDIO_DI | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_AUDIODO | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MIN,
    Board_AUDIO_CLK | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_DP2 | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_DP1 | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_DP0 | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_DP3 | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_UART_RX | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_UART_TX | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL,
    Board_DEVPK_ID | PIN_INPUT_EN | PIN_NOPULL,
    Board_SPI0_MOSI | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_SPI0_MISO | PIN_INPUT_EN | PIN_PULLDOWN,
    Board_SPI0_CLK | PIN_INPUT_EN | PIN_PULLDOWN,
Board_SPI0_MOSI | PIN_INPUT_EN | PIN_PULLDOWN, /*
SPI master out - slave in */
Board_SPI0_MISO | PIN_INPUT_EN | PIN_PULLDOWN, /*
SPI master in - slave out */
Board_SPI0_CLK | PIN_INPUT_EN | PIN_PULLDOWN, /*
SPI clock */
PIN_TERMINATE
const PINCC26XX_HWAttrs PINCC26XX_hwAttrs = {
    .intPriority = ~0,
    .swiPriority = 0
 *  ============================= Power begin ==================================
const PowerCC26XX_Config PowerCC26XX_config = {
    .policyInitFxn      = NULL,
    .policyFxn          = &PowerCC26XX_standbyPolicy,
    .calibrateFxn       = &PowerCC26XX_calibrate,
    .enablePolicy       = TRUE,
    .calibrateRCOSC_LF  = TRUE,
    .calibrateRCOSC_HF  = TRUE,
 *  ============================= Power end ===================================
 *  ============================= UART begin ===================================
#pragma DATA_SECTION(UART_config, ".const:UART_config")
#pragma DATA_SECTION(uartCC26XXHWAttrs, ".const:uartCC26XXHWAttrs")
#endif
/* Include drivers */
#include <ti/drivers/UART.h>
#include <ti/drivers/uart/UARTCC26XX.h>
/* UART objects */
UARTCC26XX_Object uartCC26XXObjects[CC2650STK_UARTCOUNT];
/* UART hardware parameter structure, also used to assign UART pins */
const UARTCC26XX_HWAttrsV1 uartCC26XXHWAttrs[CC2650STK_UARTCOUNT] = {
        .baseAddr       = UART0_BASE,
        .powerMngrId    = PowerCC26XX_PERIPH_UART0,
        .intNum         = INT_UART0_COMB,
        .intPriority    = ~0,
        .swiPriority    = 0,
        .txPin          = Board_UART_TX,
        .rxPin          = Board_UART_RX,
        .ctsPin         = PIN_UNASSIGNED,
        .rtsPin         = PIN_UNASSIGNED
/* UART configuration structure */
const UART_Config UART_config[] = {
        .fxnTablePtr = &UARTCC26XX_fxnTable,
        .object      = &uartCC26XXObjects[0],
        .hwAttrs     = &uartCC26XXHWAttrs[0]
    {NULL, NULL, NULL}
 *  ============================= UART end =====================================
 *  ============================= UDMA begin ===================================
#pragma DATA_SECTION(UDMACC26XX_config, ".const:UDMACC26XX_config")
#pragma DATA_SECTION(udmaHWAttrs, ".const:udmaHWAttrs")
#endif
#include <ti/drivers/dma/UDMACC26XX.h>
/* UDMA objects */
UDMACC26XX_Object udmaObjects[CC2650STK_UDMACOUNT];
/* UDMA configuration structure */
const UDMACC26XX_HWAttrs udmaHWAttrs[CC2650STK_UDMACOUNT] = {
        .baseAddr    = UDMA0_BASE,
        .powerMngrId = PowerCC26XX_PERIPH_UDMA,
        .intNum      = INT_DMA_ERR,
        .intPriority = ~0
const UDMACC26XX_Config UDMACC26XX_config[] = {
         .object  = &udmaObjects[0],
         .hwAttrs = &udmaHWAttrs[0]
    {NULL, NULL}
 *  ============================= UDMA end =====================================
 *  ========================== SPI DMA begin ===================================
#pragma DATA_SECTION(SPI_config, ".const:SPI_config")
#pragma DATA_SECTION(spiCC26XXDMAHWAttrs, ".const:spiCC26XXDMAHWAttrs")
#endif
#include <ti/drivers/spi/SPICC26XXDMA.h>
/* SPI objects */
SPICC26XXDMA_Object spiCC26XXDMAObjects[CC2650STK_SPICOUNT];
/* SPI configuration structure, describing which pins are to be used */
const SPICC26XXDMA_HWAttrsV1 spiCC26XXDMAHWAttrs[CC2650STK_SPICOUNT] = {
        .baseAddr           = SSI0_BASE,
        .intNum             = INT_SSI0_COMB,
        .intPriority        = ~0,
        .swiPriority        = 0,
        .powerMngrId        = PowerCC26XX_PERIPH_SSI0,
        .defaultTxBufValue  = 0,
        .rxChannelBitMask   = 1<<UDMA_CHAN_SSI0_RX,
        .txChannelBitMask   = 1<<UDMA_CHAN_SSI0_TX,
        .mosiPin            = Board_SPI0_MOSI,
        .misoPin            = Board_SPI0_MISO,
        .clkPin             = Board_SPI0_CLK,
        .csnPin             = Board_SPI0_CSN
        .baseAddr           = SSI1_BASE,
        .intNum             = INT_SSI1_COMB,
        .intPriority        = ~0,
        .swiPriority        = 0,
        .powerMngrId        = PowerCC26XX_PERIPH_SSI1,
        .rxChannelBitMask   = 1<<UDMA_CHAN_SSI1_RX,
        .txChannelBitMask   = 1<<UDMA_CHAN_SSI1_TX,
        .mosiPin            = Board_SPI1_MOSI,
        .misoPin            = Board_SPI1_MISO,
        .clkPin             = Board_SPI1_CLK,
        .csnPin             = Board_SPI1_CSN
/* SPI configuration structure */
const SPI_Config SPI_config[] = {
         .fxnTablePtr = &SPICC26XXDMA_fxnTable,
         .object      = &spiCC26XXDMAObjects[0],
         .hwAttrs     = &spiCC26XXDMAHWAttrs[0]
         .object      = &spiCC26XXDMAObjects[1],
         .hwAttrs     = &spiCC26XXDMAHWAttrs[1]
    {NULL, NULL, NULL}
 *  ========================== SPI DMA end =====================================
 *  ============================= I2C Begin=====================================
#pragma DATA_SECTION(I2C_config, ".const:I2C_config")
#pragma DATA_SECTION(i2cCC26xxHWAttrs, ".const:i2cCC26xxHWAttrs")
#endif
#include <ti/drivers/i2c/I2CCC26XX.h>
/* I2C objects */
I2CCC26XX_Object i2cCC26xxObjects[CC2650STK_I2CCOUNT];
/* I2C configuration structure, describing which pins are to be used */
const I2CCC26XX_HWAttrsV1 i2cCC26xxHWAttrs[CC2650STK_I2CCOUNT] = {
        .baseAddr = I2C0_BASE,
        .powerMngrId = PowerCC26XX_PERIPH_I2C0,
        .intNum = INT_I2C_IRQ,
        .intPriority = ~0,
        .swiPriority = 0,
        .sdaPin = Board_I2C0_SDA0,
        .sclPin = Board_I2C0_SCL0,
const I2C_Config I2C_config[] = {
        .fxnTablePtr = &I2CCC26XX_fxnTable,
        .object = &i2cCC26xxObjects[0],
        .hwAttrs = &i2cCC26xxHWAttrs[0]
    {NULL, NULL, NULL}
 *  ========================== I2C end =========================================
 *  ========================== Crypto begin ====================================
 *  NOTE: The Crypto implementation should be considered experimental
 *        and not validated!
#pragma DATA_SECTION(CryptoCC26XX_config, ".const:CryptoCC26XX_config")
#pragma DATA_SECTION(cryptoCC26XXHWAttrs, ".const:cryptoCC26XXHWAttrs")
#endif
#include <ti/drivers/crypto/CryptoCC26XX.h>
/* Crypto objects */
CryptoCC26XX_Object cryptoCC26XXObjects[CC2650STK_CRYPTOCOUNT];
/* Crypto configuration structure, describing which pins are to be used */
const CryptoCC26XX_HWAttrs cryptoCC26XXHWAttrs[CC2650STK_CRYPTOCOUNT] = {
        .baseAddr       = CRYPTO_BASE,
        .powerMngrId    = PowerCC26XX_PERIPH_CRYPTO,
        .intNum         = INT_CRYPTO_RESULT_AVAIL_IRQ,
        .intPriority    = ~0,
/* Crypto configuration structure */
const CryptoCC26XX_Config CryptoCC26XX_config[] = {
         .object  = &cryptoCC26XXObjects[0],
         .hwAttrs = &cryptoCC26XXHWAttrs[0]
    {NULL, NULL}
 *  ========================== Crypto end ======================================
 *  ============================= PDM begin ====================================
#pragma DATA_SECTION(PDMCC26XX_config, ".const:PDMCC26XX_config")
#pragma DATA_SECTION(pdmCC26XXHWAttrs, ".const:pdmCC26XXHWAttrs")
#pragma DATA_SECTION(PDMCC26XX_I2S_config, ".const:PDMCC26XX_I2S_config")
#endif
#include <ti/drivers/pdm/PDMCC26XX.h>
#include <ti/drivers/pdm/PDMCC26XX_util.h>
/* PDM objects, one for PDM driver, one for PDM/I2S helper file */
PDMCC26XX_Object pdmCC26XXObjects[CC2650STK_PDMCOUNT];
PDMCC26XX_I2S_Object pdmCC26XXI2SObjects[CC2650STK_PDMCOUNT];
/* PDM driver hardware attributes */
const PDMCC26XX_HWAttrs pdmCC26XXHWAttrs[CC2650STK_PDMCOUNT] = {
        .micPower = Board_MIC_POWER,
        .taskPriority = 2
/* PDM configuration structure */
const PDMCC26XX_Config PDMCC26XX_config[] = {
        .object = &pdmCC26XXObjects[0],
        .hwAttrs = &pdmCC26XXHWAttrs[0]
/* PDM_I2S hardware attributes */
const PDMCC26XX_I2S_HWAttrs pdmC26XXI2SHWAttrs[CC2650STK_PDMCOUNT] = {
        .baseAddr       = I2S0_BASE,
        .intNum         = INT_I2S_IRQ,
        .powerMngrId    = PowerCC26XX_PERIPH_I2S,
        .intPriority    = ~0,
        .mclkPin        = PIN_UNASSIGNED,
        .bclkPin        = Board_AUDIO_CLK,
        .wclkPin        = PIN_UNASSIGNED,
        .ad0Pin         = Board_AUDIO_DI,
/* PDM_I2S configuration structure */
const PDMCC26XX_I2S_Config PDMCC26XX_I2S_config[] = {
        .object  = &pdmCC26XXI2SObjects[0],
        .hwAttrs = &pdmC26XXI2SHWAttrs[0]
    { NULL, NULL }
 *  ============================= PDM end ======================================
 *  ========================= RF driver begin ==================================
#include <ti/drivers/rf/RF.h>
/* RF hwi and swi priority */
const RFCC26XX_HWAttrs RFCC26XX_hwAttrs = {
    .hwiCpe0Priority = ~0,
    .hwiHwPriority   = ~0,
    .swiCpe0Priority =  5,
    .swiHwPriority   =  5,
 *  ========================== RF driver end ===================================
 *  ========================= Display begin ====================================
#pragma DATA_SECTION(Display_config, ".const:Display_config")
#pragma DATA_SECTION(displaySharpHWattrs, ".const:displaySharpHWattrs")
#pragma DATA_SECTION(displayUartHWAttrs, ".const:displayUartHWAttrs")
#endif
#include <ti/mw/display/Display.h>
#include <ti/mw/display/DisplaySharp.h>
#include <ti/mw/display/DisplayUart.h>
/* Structures for UartPlain Blocking */
DisplayUart_Object        displayUartObject;
#ifndef BOARD_DISPLAY_UART_STRBUF_SIZE
#define BOARD_DISPLAY_UART_STRBUF_SIZE    128
#endif
static char uartStringBuf[BOARD_DISPLAY_UART_STRBUF_SIZE];
const DisplayUart_HWAttrs displayUartHWAttrs = {
    .uartIdx      = Board_UART,
    .baudRate     =     115200,
    .mutexTimeout = BIOS_WAIT_FOREVER,
    .strBuf = uartStringBuf,
    .strBufLen = BOARD_DISPLAY_UART_STRBUF_SIZE,
/* Structures for SHARP */
DisplaySharp_Object displaySharpObject;
#ifndef BOARD_DISPLAY_SHARP_SIZE
#define BOARD_DISPLAY_SHARP_SIZE    96 // 96->96x96 is the most common board, alternative is 128->128x128.
#endif
static uint8_t sharpDisplayBuf[BOARD_DISPLAY_SHARP_SIZE * BOARD_DISPLAY_SHARP_SIZE / 8];
const DisplaySharp_HWAttrs displaySharpHWattrs = {
    .spiIndex    = Board_SPI0,
    .csPin       = Board_LCD_CS,
    .extcominPin = Board_LCD_EXTCOMIN,
    .powerPin    = Board_LCD_POWER,
    .enablePin   = Board_LCD_ENABLE,
    .pixelWidth  = BOARD_DISPLAY_SHARP_SIZE,
    .pixelHeight = BOARD_DISPLAY_SHARP_SIZE,
    .displayBuf  = sharpDisplayBuf,
/* As the pins for UART and Watch Devpack conflict, prefer UART by default */
#if !defined(BOARD_DISPLAY_EXCLUDE_UART) && !defined(BOARD_DISPLAY_EXCLUDE_LCD)
#  define BOARD_DISPLAY_EXCLUDE_LCD
#endif
/* Array of displays */
const Display_Config Display_config[] = {
        .fxnTablePtr = &DisplayUart_fxnTable,
        .object      = &displayUartObject,
        .hwAttrs     = &displayUartHWAttrs,
#endif
#if !defined(BOARD_DISPLAY_EXCLUDE_LCD)
        .fxnTablePtr = &DisplaySharp_fxnTable,
        .object      = &displaySharpObject,
        .hwAttrs     = &displaySharpHWattrs
#endif
    { NULL, NULL, NULL } // Terminator
 *  ========================= Display end ======================================
6012.CC2650STK.h
    The CC2650MODA doesn't contain the sensors that the sensortag has. The CC2650MODA only contains one integrated temperature sensor therefore you need to connect any other sensors you want to use and interface with them before you are able to send that data to the mobile app.
    Gerardo
  • Hi Gerardo, Thanks for your reply.
    Yes I have already connected sensor to CC2650MODA, so no issues with hardware connection.
    My question is,
    1. If we look at mobile screen shoot above, we can see there is no any graph for IR temp data. Does it mean that, TEMPERATURE service is not working ?
    2. What modifications do I need to make in Board files to use I2C in cc2650MODA ?
  • 1. Can you try reading that characteristic from an application like LightBlue or BLE Scanner to see if a value is reported. Can you also ensure you are getting meaningful data from your sensor by printing out the value that is used to update the BLE data being read or adding a breakpoint to inspect this value.
    2. It looks like you already have an I2C instance on your board file, is that not working?
    Gerardo
  • Hi Gerardo,
    Thanks for your reply, it was very helpful.
    I used LIGHTBLUE app and found an issue as follow.
    A. In case of Sensortag, (F000AA01 = IR Temp sensor data; F000AA02 = IR Config data)
    value of service F000AA01 == 0000 and F000AA02 == 00 (service is disabled),
                         When I send F000AA02 == 01 through LIGHTBLE mobile app, I could see following change
    value of service F000AA01 == F3AA and F000AA02 == 01 (service is enabled)
    and value of F000AA01 changes in accordance with temperature.
    B. In case of CC2650MODA, (F000AA01 = IR Temp sensor data; F000AA02 = IR Config data)
    value of service F000AA01 == 0000 and F000AA02 == FF (I dont know, what does it mean ?)
    and value of F000AA01 always remains 0000.
    Please find attached image for more reference.
    In both cases, code remains same only change is Sensortag (is with #define CC2650EM_7ID) and CC2650MODA (is with #define CC2650EM_5XD).
    I2C line is working perfect, I was able to read sensor data with help of Arduino. So there is no any problem with I2C hardware side.
    I am using SDA and SCL pins as follow.
    #define Board_I2C0_SDA0 IOID_5 // Pin no 11 on CC2650MODA
    #define Board_I2C0_SCL0 IOID_6 // Pin no 12 on CC2650MODA
    Can you suggest, what else should I try ?
  • Is the code you are using on the sensortag and the CC2650MODA identical apart from the Board file changes?
    Gerardo
