Other Parts Discussed in Thread: LAUNCHXL-CC2640R2
Hello Team,
In Github example "BLE5-Stack Long Range Central" described:
A GATT write to the Throughput PHY Characteristic to have the peripheral start negotiation the use of the Coded PHY (S8).
As I understand, we can use Long range mode only after connecting at short range, isnt it?
It looks strange.. For example if you make a data acquisition system and instal it in the large house, after system power down you should reupdate every node?
In this case you will need to take every node close to the Central Station to establish link with Coded PHY (S8) for long range connection.
Please clarify this for us.
We have 5 CC2640R2F Launchpads, please help us ot understand how to make a Long Range Link at long range :)
We tested the examples and we see strong range improvement, but after power down we need again at first connect nodes at short range. this is not suitable for our application.
Ilya.
