Part Number: CC2640R2F
I am working on CC2640R2F and am planning to receive serial data through UART and send it to BLE scanner.I have defined the UART in callback mode.Ive been trying this for weeks but all in vain.Any help would be greatly appreciated .I have used project zero as the base for my project and my code is as folllows.The UART read function never gets called back at .I have tried changing the code in every way.I also tried blocking mode and direct function call but it blocks the blueooth connection and hangs.I have also tried the same on SimpleBLEperipheral but the same thing keeps happening.
following is my code:
//PROJECT.C
* Copyright (c) 2016, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* INCLUDES
#include <string.h>
#include <stddef.h>
#include <stdint.h>
//#define xdc_runtime_Log_DISABLE_ALL 1 // Add to disable logs from this file
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Queue.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/drivers/PIN.h>
#include <ti/display/Display.h>
#include <ti/drivers/UART.h>
#include <ti/drivers/GPIO.h>
#include <xdc/runtime/Log.h>
#include <xdc/runtime/Diags.h>
#include <UartLog.h>
/* This Header file contains all BLE API and icall structure definition */
#include "icall_ble_api.h"
#include <icall.h>
#include <osal_snv.h>
#include <peripheral.h>
#include <devinfoservice.h>
#include "util.h"
#include "Board.h"
#include "project_zero.h"
// Bluetooth Developer Studio services
#include "led_service.h"
#include "button_service.h"
#include "data_service.h"
* CONSTANTS
#define BUFSIZE 4
// Advertising interval when device is discoverable (units of 625us, 160=100ms)
#define DEFAULT_ADVERTISING_INTERVAL 160
// Limited discoverable mode advertises for 30.72s, and then stops
// General discoverable mode advertises indefinitely
#define DEFAULT_DISCOVERABLE_MODE GAP_ADTYPE_FLAGS_GENERAL
// Default pass-code used for pairing.
#define DEFAULT_PASSCODE 000000
// Task configuration
#define PRZ_TASK_PRIORITY 1
#ifndef PRZ_TASK_STACK_SIZE
#define PRZ_TASK_STACK_SIZE 800
#endif
// Internal Events for RTOS application
#define PRZ_ICALL_EVT ICALL_MSG_EVENT_ID // Event_Id_31
#define PRZ_QUEUE_EVT UTIL_QUEUE_EVENT_ID // Event_Id_30
#define PRZ_STATE_CHANGE_EVT Event_Id_00
#define PRZ_CHAR_CHANGE_EVT Event_Id_01
#define PRZ_PERIODIC_EVT Event_Id_02
#define PRZ_APP_MSG_EVT Event_Id_03
#define PRZ_CONN_EVT_END_EVT Event_Id_30
#define PRZ_ALL_EVENTS (PRZ_ICALL_EVT | \
PRZ_QUEUE_EVT | \
PRZ_STATE_CHANGE_EVT | \
PRZ_CHAR_CHANGE_EVT | \
PRZ_PERIODIC_EVT | \
PRZ_APP_MSG_EVT | \
PRZ_CONN_EVT_END_EVT)
* TYPEDEFS
// Types of messages that can be sent to the user application task from other
// tasks or interrupts. Note: Messages from BLE Stack are sent differently.
typedef enum
APP_MSG_SERVICE_WRITE = 0, /* A characteristic value has been written */
APP_MSG_SERVICE_CFG, /* A characteristic configuration has changed */
APP_MSG_UPDATE_CHARVAL, /* Request from ourselves to update a value */
APP_MSG_GAP_STATE_CHANGE, /* The GAP / connection state has changed */
APP_MSG_BUTTON_DEBOUNCED, /* A button has been debounced with new value */
APP_MSG_SEND_PASSCODE, /* A pass-code/PIN is requested during pairing */
} app_msg_types_t;
// Struct for messages sent to the application task
typedef struct
Queue_Elem _elem;
app_msg_types_t type;
uint8_t pdu[];
} app_msg_t;
// Struct for messages about characteristic data
typedef struct
uint16_t svcUUID; // UUID of the service
uint16_t dataLen; //
uint8_t paramID; // Index of the characteristic
uint8_t data[]; // Flexible array member, extended to malloc - sizeof(.)
} char_data_t;
// Struct for message about sending/requesting passcode from peer.
typedef struct
uint16_t connHandle;
uint8_t uiInputs;
uint8_t uiOutputs;
uint32 numComparison;
} passcode_req_t;
// Struct for message about button state
typedef struct
PIN_Id pinId;
uint8_t state;
} button_state_t;
* LOCAL VARIABLES
// Entity ID globally used to check for source and/or destination of messages
static ICall_EntityID selfEntity;
// Event globally used to post local events and pend on system and
// local events.
static ICall_SyncHandle syncEvent;
// Queue object used for application messages.
static Queue_Struct applicationMsgQ;
static Queue_Handle hApplicationMsgQ;
Task_Struct przTask;
Char przTaskStack[PRZ_TASK_STACK_SIZE];
// GAP - SCAN RSP data (max size = 31 bytes)
static uint8_t scanRspData[] =
// No scan response data provided.
0x00 // Placeholder to keep the compiler happy.
// GAP - Advertisement data (max size = 31 bytes, though this is
// best kept short to conserve power while advertisting)
static uint8_t advertData[] =
// Flags; this sets the device to use limited discoverable
// mode (advertises for 30 seconds at a time) or general
// discoverable mode (advertises indefinitely), depending
// on the DEFAULT_DISCOVERY_MODE define.
0x02, // length of this data
GAP_ADTYPE_FLAGS,
DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
// complete name
16,
GAP_ADTYPE_LOCAL_NAME_COMPLETE,
'P', 'r', 'o', 'j', 'e', 'c', 't', ' ', 'Z', 'e', 'r', 'o', ' ','R','2',
// GAP GATT Attributes
static uint8_t attDeviceName[GAP_DEVICE_NAME_LEN] = "Project Zero R2";
// Globals used for ATT Response retransmission
static gattMsgEvent_t *pAttRsp = NULL;
static uint8_t rspTxRetry = 0;
/* Pin driver handles */
static PIN_Handle buttonPinHandle;
static PIN_Handle ledPinHandle;
/* Global memory storage for a PIN_Config table */
static PIN_State ledPinState;
* Initial LED pin configuration table
* - LEDs Board_LED0 & Board_LED1 are off.
PIN_Config ledPinTable[] = {
Board_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
Board_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
PIN_TERMINATE
* Application button pin configuration table:
* - Buttons interrupts are configured to trigger on falling edge.
static PIN_State buttonPinState;
PIN_Config buttonPinTable[] = {
Board_BUTTON0 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_NEGEDGE,
Board_BUTTON1 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_NEGEDGE,
PIN_TERMINATE
// Clock objects for debouncing the buttons
static Clock_Struct button0DebounceClock;
static Clock_Struct button1DebounceClock;
// State of the buttons
static uint8_t button0State = 0;
static uint8_t button1State = 0;
// Global display handle
Display_Handle dispHandle;
//global uart handler and buffers
uint8_t *rxBuf1[BUFSIZE];
uint8_t *rxBuf2[BUFSIZE];
UART_Handle uart;
UART_Params uartParams;
* LOCAL FUNCTIONS
static void ProjectZero_init( void );
static void ProjectZero_taskFxn(UArg a0, UArg a1);
static void user_processApplicationMessage(app_msg_t *pMsg);
static uint8_t ProjectZero_processStackMsg(ICall_Hdr *pMsg);
static uint8_t ProjectZero_processGATTMsg(gattMsgEvent_t *pMsg);
static void ProjectZero_sendAttRsp(void);
static void ProjectZero_freeAttRsp(uint8_t status);
static void user_processGapStateChangeEvt(gaprole_States_t newState);
static void user_gapStateChangeCB(gaprole_States_t newState);
static void user_gapBondMgr_passcodeCB(uint8_t *deviceAddr, uint16_t connHandle,
uint8_t uiInputs, uint8_t uiOutputs, uint32 numComparison);
static void user_gapBondMgr_pairStateCB(uint16_t connHandle, uint8_t state,
uint8_t status);
static void buttonDebounceSwiFxn(UArg buttonId);
static void user_handleButtonPress(button_state_t *pState);
// Generic callback handlers for value changes in services.
static void user_service_ValueChangeCB( uint16_t connHandle, uint16_t svcUuid, uint8_t paramID, uint8_t *pValue, uint16_t len );
static void user_service_CfgChangeCB( uint16_t connHandle, uint16_t svcUuid, uint8_t paramID, uint8_t *pValue, uint16_t len );
// Task context handlers for generated services.
static void user_LedService_ValueChangeHandler(char_data_t *pCharData);
static void user_ButtonService_CfgChangeHandler(char_data_t *pCharData);
static void user_DataService_ValueChangeHandler(char_data_t *pCharData);
static void user_DataService_CfgChangeHandler(char_data_t *pCharData);
// Task handler for sending notifications.
static void user_updateCharVal(char_data_t *pCharData);
// Utility functions
static void user_enqueueRawAppMsg(app_msg_types_t appMsgType, uint8_t *pData, uint16_t len );
static void user_enqueueCharDataMsg(app_msg_types_t appMsgType, uint16_t connHandle,
uint16_t serviceUUID, uint8_t paramID,
uint8_t *pValue, uint16_t len);
static void buttonCallbackFxn(PIN_Handle handle, PIN_Id pinId);
static char *Util_convertArrayToHexString(uint8_t const *src, uint8_t src_len,
uint8_t *dst, uint8_t dst_len);
static char *Util_getLocalNameStr(const uint8_t *data);
static void dearhope();
static void uartread(UART_Handle uart, void *buf, size_t count);
* EXTERN FUNCTIONS
extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
* PROFILE CALLBACKS
// GAP Role Callbacks
static gapRolesCBs_t user_gapRoleCBs =
user_gapStateChangeCB // Profile State Change Callbacks
// GAP Bond Manager Callbacks
static gapBondCBs_t user_bondMgrCBs =
user_gapBondMgr_passcodeCB, // Passcode callback
user_gapBondMgr_pairStateCB // Pairing / Bonding state Callback
* Callbacks in the user application for events originating from BLE services.
// LED Service callback handler.
// The type LED_ServiceCBs_t is defined in led_service.h
static LedServiceCBs_t user_LED_ServiceCBs =
.pfnChangeCb = user_service_ValueChangeCB, // Characteristic value change callback handler
.pfnCfgChangeCb = NULL, // No notification-/indication enabled chars in LED Service
// Button Service callback handler.
// The type Button_ServiceCBs_t is defined in button_service.h
static ButtonServiceCBs_t user_Button_ServiceCBs =
.pfnChangeCb = NULL, // No writable chars in Button Service, so no change handler.
.pfnCfgChangeCb = user_service_CfgChangeCB, // Noti/ind configuration callback handler
// Data Service callback handler.
// The type Data_ServiceCBs_t is defined in data_service.h
static DataServiceCBs_t user_Data_ServiceCBs =
* PUBLIC FUNCTIONS
* @brief Task creation function for the user task.
* @param None.
* @return None.
void ProjectZero_createTask(void)
Task_Params taskParams;
// Configure task
Task_Params_init(&taskParams);
taskParams.stack = przTaskStack;
taskParams.stackSize = PRZ_TASK_STACK_SIZE;
taskParams.priority = PRZ_TASK_PRIORITY;
Task_construct(&przTask, ProjectZero_taskFxn, &taskParams, NULL);
* @brief Called before the task loop and contains application-specific
* initialization of the BLE stack, hardware setup, power-state
* notification if used, and BLE profile/service initialization.
* @param None.
* @return None.
static void ProjectZero_init(void)
// NO STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
// Register the current thread as an ICall dispatcher application
// so that the application can send and receive messages via ICall to Stack.
ICall_registerApp(&selfEntity, &syncEvent);
Log_info0("Initializing the user task, hardware, BLE stack and services.");
Log_info0("\n lets call it");
// Open display. By default this is disabled via the predefined symbol Display_DISABLE_ALL.
dispHandle = Display_open(Display_Type_UART, NULL);
// Initialize queue for application messages.
// Note: Used to transfer control to application thread from e.g. interrupts.
Queue_construct(&applicationMsgQ, NULL);
hApplicationMsgQ = Queue_handle(&applicationMsgQ);
// Hardware initialization
// Open LED pins
ledPinHandle = PIN_open(&ledPinState, ledPinTable);
if(!ledPinHandle) {
Log_error0("Error initializing board LED pins");
Task_exit();
buttonPinHandle = PIN_open(&buttonPinState, buttonPinTable);
if(!buttonPinHandle) {
Log_error0("Error initializing button pins");
Task_exit();
// Setup callback for button pins
if (PIN_registerIntCb(buttonPinHandle, &buttonCallbackFxn) != 0) {
Log_error0("Error registering button callback function");
Task_exit();
// Create the debounce clock objects for Button 0 and Button 1
Clock_Params clockParams;
Clock_Params_init(&clockParams);
// Both clock objects use the same callback, so differentiate on argument
// given to the callback in Swi context
clockParams.arg = Board_BUTTON0;
// Initialize to 50 ms timeout when Clock_start is called.
// Timeout argument is in ticks, so convert from ms to ticks via tickPeriod.
Clock_construct(&button0DebounceClock, buttonDebounceSwiFxn,
50 * (1000/Clock_tickPeriod),
&clockParams);
// Second button
clockParams.arg = Board_BUTTON1;
Clock_construct(&button1DebounceClock, buttonDebounceSwiFxn,
&clockParams);
// BLE Stack initialization
// Setup the GAP Peripheral Role Profile
uint8_t initialAdvertEnable = TRUE; // Advertise on power-up
// By setting this to zero, the device will go into the waiting state after
// being discoverable. Otherwise wait this long [ms] before advertising again.
uint16_t advertOffTime = 0; // miliseconds
// Set advertisement enabled.
GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t),
&initialAdvertEnable);
// Configure the wait-time before restarting advertisement automatically
GAPRole_SetParameter(GAPROLE_ADVERT_OFF_TIME, sizeof(uint16_t),
&advertOffTime);
// Initialize Scan Response data
GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData), scanRspData);
// Initialize Advertisement data
GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
Log_info1("Name in advertData array: \x1b[33m%s\x1b[0m",
(IArg)Util_getLocalNameStr(advertData));
// Set advertising interval
uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MIN, advInt);
GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MAX, advInt);
GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MIN, advInt);
GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MAX, advInt);
// Set duration of advertisement before stopping in Limited adv mode.
GAP_SetParamValue(TGAP_LIM_ADV_TIMEOUT, 30); // Seconds
// BLE Bond Manager initialization
uint32_t passkey = 0; // passkey "000000"
uint8_t pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
uint8_t mitm = TRUE;
uint8_t ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
uint8_t bonding = TRUE;
GAPBondMgr_SetParameter(GAPBOND_DEFAULT_PASSCODE, sizeof(uint32_t),
&passkey);
GAPBondMgr_SetParameter(GAPBOND_PAIRING_MODE, sizeof(uint8_t), &pairMode);
GAPBondMgr_SetParameter(GAPBOND_MITM_PROTECTION, sizeof(uint8_t), &mitm);
GAPBondMgr_SetParameter(GAPBOND_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
GAPBondMgr_SetParameter(GAPBOND_BONDING_ENABLED, sizeof(uint8_t), &bonding);
// BLE Service initialization
// Add services to GATT server
GGS_AddService(GATT_ALL_SERVICES); // GAP
GATTServApp_AddService(GATT_ALL_SERVICES); // GATT attributes
DevInfo_AddService(); // Device Information Service
// Set the device name characteristic in the GAP Profile
GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
// Add services to GATT server and give ID of this task for Indication acks.
LedService_AddService( selfEntity );
ButtonService_AddService( selfEntity );
DataService_AddService( selfEntity );
// Register callbacks with the generated services that
// can generate events (writes received) to the application
LedService_RegisterAppCBs( &user_LED_ServiceCBs );
ButtonService_RegisterAppCBs( &user_Button_ServiceCBs );
DataService_RegisterAppCBs( &user_Data_ServiceCBs );
// Placeholder variable for characteristic intialization
uint8_t initVal[40] = {0};
uint8_t initString[] = "This is a pretty long string, isn't it!";
// Initalization of characteristics in LED_Service that can provide data.
LedService_SetParameter(LS_LED0_ID, LS_LED0_LEN, initVal);
LedService_SetParameter(LS_LED1_ID, LS_LED1_LEN, initVal);
// Initalization of characteristics in Button_Service that can provide data.
ButtonService_SetParameter(BS_BUTTON0_ID, BS_BUTTON0_LEN, initVal);
ButtonService_SetParameter(BS_BUTTON1_ID, BS_BUTTON1_LEN, initVal);
// Initalization of characteristics in Data_Service that can provide data.
DataService_SetParameter(DS_STRING_ID, sizeof(initString), initString);
DataService_SetParameter(DS_STREAM_ID, DS_STREAM_LEN, initVal);
// Start the stack in Peripheral mode.
VOID GAPRole_StartDevice(&user_gapRoleCBs);
// Start Bond Manager
VOID GAPBondMgr_Register(&user_bondMgrCBs);
// Register with GAP for HCI/Host messages
GAP_RegisterForMsgs(selfEntity);
// Register for GATT local events and ATT Responses pending for transmission
GATT_RegisterForMsgs(selfEntity);
Log_info0("\n calling dearhope");
dearhope();
* @brief Application task entry point.
* Invoked by TI-RTOS when BIOS_start is called. Calls an init function
* and enters an infinite loop waiting for messages.
* Messages can be either directly from the BLE stack or from user code
* like Hardware Interrupt (Hwi) or a callback function.
* The reason for sending messages to this task from e.g. Hwi's is that
* some RTOS and Stack APIs are not available in callbacks and so the
* actions that may need to be taken is dispatched to this Task.
* @param a0, a1 - not used.
* @return None.
Log_info0("\n going ");
// Initialize application
ProjectZero_init();
// Application main loop
for (;;)
uint32_t events;
// Waits for an event to be posted associated with the calling thread.
// Note that an event associated with a thread is posted when a
// message is queued to the message receive queue of the thread
events = Event_pend(syncEvent, Event_Id_NONE, PRZ_ALL_EVENTS,
ICALL_TIMEOUT_FOREVER);
if (events)
ICall_EntityID dest;
ICall_ServiceEnum src;
ICall_HciExtEvt *pMsg = NULL;
// Check if we got a signal because of a stack message
if (ICall_fetchServiceMsg(&src, &dest,
(void **)&pMsg) == ICALL_ERRNO_SUCCESS)
uint8 safeToDealloc = TRUE;
if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
// Check for event flags received (event signature 0xffff)
if (pEvt->signature == 0xffff)
// Event received when a connection event is completed
if (pEvt->event_flag & PRZ_CONN_EVT_END_EVT)
// Try to retransmit pending ATT Response (if any)
ProjectZero_sendAttRsp();
else // It's a message from the stack and not an event.
// Process inter-task message
safeToDealloc = ProjectZero_processStackMsg((ICall_Hdr *)pMsg);
if (pMsg && safeToDealloc)
ICall_freeMsg(pMsg);
// Process messages sent from another task or another context.
while (!Queue_empty(hApplicationMsgQ))
app_msg_t *pMsg = Queue_dequeue(hApplicationMsgQ);
// Process application-layer message probably sent from ourselves.
user_processApplicationMessage(pMsg);
// Free the received message.
ICall_free(pMsg);
* @brief Handle application messages
* These are messages not from the BLE stack, but from the
* application itself.
* For example, in a Software Interrupt (Swi) it is not possible to
* call any BLE APIs, so instead the Swi function must send a message
* to the application Task for processing in Task context.
* @param pMsg Pointer to the message of type app_msg_t.
* @return None.
char_data_t *pCharData = (char_data_t *)pMsg->pdu;int i;
switch (pMsg->type)
case APP_MSG_SERVICE_WRITE: /* Message about received value write */
/* Call different handler per service */
switch(pCharData->svcUUID) {
case LED_SERVICE_SERV_UUID:
user_LedService_ValueChangeHandler(pCharData);
Log_info0("\n processing");
for(i=0;i<4;i++)
pCharData->data[i]=&rxBuf1[i];
for(i=0;i<4;i++)
pCharData->data[i]=&rxBuf2[i];
DataService_SetParameter(DS_STREAM_ID,4,*rxBuf1);
DataService_SetParameter(DS_STRING_ID,sizeof(rxBuf2),*rxBuf2);
break;
case DATA_SERVICE_SERV_UUID:
user_DataService_ValueChangeHandler(pCharData);
break;
break;
case APP_MSG_SERVICE_CFG: /* Message about received CCCD write */
case BUTTON_SERVICE_SERV_UUID:
user_ButtonService_CfgChangeHandler(pCharData);
break;
user_DataService_CfgChangeHandler(pCharData);
break;
break;
case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
break;
case APP_MSG_UPDATE_CHARVAL: /* Message from ourselves to send */
user_updateCharVal(pCharData);
break;
case APP_MSG_GAP_STATE_CHANGE: /* Message that GAP state changed */
user_processGapStateChangeEvt( *(gaprole_States_t *)pMsg->pdu );
break;
case APP_MSG_SEND_PASSCODE: /* Message about pairing PIN request */
passcode_req_t *pReq = (passcode_req_t *)pMsg->pdu;
Log_info2("BondMgr Requested passcode. We are %s passcode %06d",
(IArg)(pReq->uiInputs?"Sending":"Displaying"),
DEFAULT_PASSCODE);
// Send passcode response.
GAPBondMgr_PasscodeRsp(pReq->connHandle, SUCCESS, DEFAULT_PASSCODE);
break;
case APP_MSG_BUTTON_DEBOUNCED: /* Message from swi about pin change */
button_state_t *pButtonState = (button_state_t *)pMsg->pdu;
user_handleButtonPress(pButtonState);
break;
* Handlers of system/application events deferred to the user Task context.
* Invoked from the application Task function above.
* Further down you can find the callback handler section containing the
* functions that defer their actions via messages to the application task.
* @brief Process a pending GAP Role state change event.
* @param newState - new state
* @return None.
switch ( newState )
case GAPROLE_STARTED:
uint8_t ownAddress[B_ADDR_LEN];
uint8_t systemId[DEVINFO_SYSTEM_ID_LEN];
GAPRole_GetParameter(GAPROLE_BD_ADDR, ownAddress);
// use 6 bytes of device address for 8 bytes of system ID value
systemId[0] = ownAddress[0];
systemId[1] = ownAddress[1];
systemId[2] = ownAddress[2];
// set middle bytes to zero
systemId[4] = 0x00;
systemId[3] = 0x00;
// shift three bytes up
systemId[7] = ownAddress[5];
systemId[6] = ownAddress[4];
systemId[5] = ownAddress[3];
DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
// Display device address
char *cstr_ownAddress = Util_convertBdAddr2Str(ownAddress);
Log_info1("GAP is started. Our address: \x1b[32m%s\x1b[0m", (IArg)cstr_ownAddress);
break;
case GAPROLE_ADVERTISING:
Log_info0("Advertising");
break;
case GAPROLE_CONNECTED:
uint8_t peerAddress[B_ADDR_LEN];
GAPRole_GetParameter(GAPROLE_CONN_BD_ADDR, peerAddress);
char *cstr_peerAddress = Util_convertBdAddr2Str(peerAddress);
Log_info1("Connected. Peer address: \x1b[32m%s\x1b[0m", (IArg)cstr_peerAddress);
break;
case GAPROLE_CONNECTED_ADV:
Log_info0("Connected and advertising");
break;
case GAPROLE_WAITING:
Log_info0("Disconnected / Idle");
break;
case GAPROLE_WAITING_AFTER_TIMEOUT:
Log_info0("Connection timed out");
break;
case GAPROLE_ERROR:
Log_info0("Error");
break;
default:
break;
* @brief Handle a debounced button press or release in Task context.
* Invoked by the taskFxn based on a message received from a callback.
* @see buttonDebounceSwiFxn
* @see buttonCallbackFxn
* @param pState pointer to button_state_t message sent from debounce Swi.
* @return None.
Log_info2("%s %s",
(IArg)(pState->pinId == Board_BUTTON0?"Button 0":"Button 1"),
(IArg)(pState->state?"\x1b[32mpressed\x1b[0m":
"\x1b[33mreleased\x1b[0m"));
// Update the service with the new value.
// Will automatically send notification/indication if enabled.
switch (pState->pinId)
case Board_BUTTON0:
sizeof(pState->state),
&pState->state);
break;
case Board_BUTTON1:
&pState->state);
break;
* @brief Handle a write request sent from a peer device.
* Invoked by the Task based on a message received from a callback.
* When we get here, the request has already been accepted by the
* service and is valid from a BLE protocol perspective as well as
* having the correct length as defined in the service implementation.
* @param pCharData pointer to malloc'd char write data
* @return None.
static uint8_t pretty_data_holder[16]; // 5 bytes as hex string "AA:BB:CC:DD:EE"
Util_convertArrayToHexString(pCharData->data, pCharData->dataLen,
pretty_data_holder, sizeof(pretty_data_holder));
switch (pCharData->paramID)
case LS_LED0_ID:
Log_info3("Value Change msg: %s %s: %s",
(IArg)"LED Service",
(IArg)"LED0",
(IArg)pretty_data_holder);
// Do something useful with pCharData->data here
// Set the output value equal to the received value. 0 is off, not 0 is on
PIN_setOutputValue(ledPinHandle, Board_RLED, pCharData->data[0]);
Log_info2("Turning %s %s",
(IArg)"\x1b[31mLED0\x1b[0m",
(IArg)(pCharData->data[0]?"on":"off"));
break;
case LS_LED1_ID:
(IArg)"LED1",
PIN_setOutputValue(ledPinHandle, Board_GLED, pCharData->data[0]);
(IArg)"\x1b[32mLED1\x1b[0m",
break;
default:
return;
* @brief Handle a CCCD (configuration change) write received from a peer
* device. This tells us whether the peer device wants us to send
* Notifications or Indications.
* @return None.
// Cast received data to uint16, as that's the format for CCCD writes.
uint16_t configValue = *(uint16_t *)pCharData->data;
char *configValString;
// Determine what to tell the user
switch(configValue)
case GATT_CFG_NO_OPERATION:
configValString = "Noti/Ind disabled";
break;
case GATT_CLIENT_CFG_NOTIFY:
configValString = "Notifications enabled";
break;
case GATT_CLIENT_CFG_INDICATE:
configValString = "Indications enabled";
break;
case BS_BUTTON0_ID:
Log_info3("CCCD Change msg: %s %s: %s",
(IArg)"Button Service",
(IArg)"BUTTON0",
(IArg)configValString);
// Do something useful with configValue here. It tells you whether someone
// wants to know the state of this characteristic.
break;
case BS_BUTTON1_ID:
(IArg)"BUTTON1",
break;
* @return None.
// Value to hold the received string for printing via Log, as Log printouts
// happen in the Idle task, and so need to refer to a global/static variable.
static uint8_t received_string[DS_STRING_LEN] = {0};
/* Create a UART with data processing off. */
case DS_STRING_ID:
// Copy received data to holder array, ensuring NULL termination.
memset(received_string, 0, DS_STRING_LEN);
memcpy(received_string, pCharData->data, DS_STRING_LEN-1);
// Needed to copy before log statement, as the holder array remains after
// the pCharData message has been freed and reused for something else.
(IArg)"Data Service",
(IArg)"String",
(IArg)received_string);
break;
case DS_STREAM_ID:
Log_info3("Value Change msg: Data Service Stream: %02x:%02x:%02x...",
(IArg)pCharData->data[0],
(IArg)pCharData->data[1],
(IArg)pCharData->data[2]);
break;
default:
return;
* @return None.
switch(configValue)
break;
break;
break;
case DS_STREAM_ID:
(IArg)"Stream",
break;
* @brief Process an incoming BLE stack message.
* This could be a GATT message from a peer device like acknowledgement
* of an Indication we sent, or it could be a response from the stack
* to an HCI message that the user application sent.
* @param pMsg - message to process
* @return TRUE if safe to deallocate incoming message, FALSE otherwise.
uint8_t safeToDealloc = TRUE;
switch (pMsg->event)
case GATT_MSG_EVENT:
// Process GATT message
safeToDealloc = ProjectZero_processGATTMsg((gattMsgEvent_t *)pMsg);
break;
case HCI_GAP_EVENT_EVENT:
// Process HCI message
switch(pMsg->status)
case HCI_COMMAND_COMPLETE_EVENT_CODE:
// Process HCI Command Complete Event
Log_info0("HCI Command Complete Event received");
break;
default:
break;
break;
default:
// do nothing
break;
return (safeToDealloc);
* @brief Process GATT messages and events.
// See if GATT server was unable to transmit an ATT response
if (pMsg->hdr.status == blePending)
Log_warning1("Outgoing RF FIFO full. Re-schedule transmission of msg with opcode 0x%02x",
pMsg->method);
// No HCI buffer was available. Let's try to retransmit the response
// on the next connection event.
if (HCI_EXT_ConnEventNoticeCmd(pMsg->connHandle, selfEntity,
PRZ_CONN_EVT_END_EVT) == SUCCESS)
// First free any pending response
ProjectZero_freeAttRsp(FAILURE);
// Hold on to the response message for retransmission
pAttRsp = pMsg;
// Don't free the response message yet
return (FALSE);
else if (pMsg->method == ATT_FLOW_CTRL_VIOLATED_EVENT)
// ATT request-response or indication-confirmation flow control is
// violated. All subsequent ATT requests or indications will be dropped.
// The app is informed in case it wants to drop the connection.
// Log the opcode of the message that caused the violation.
Log_error1("Flow control violated. Opcode of offending ATT msg: 0x%02x",
pMsg->msg.flowCtrlEvt.opcode);
else if (pMsg->method == ATT_MTU_UPDATED_EVENT)
// MTU size updated
Log_info1("MTU Size change: %d bytes", pMsg->msg.mtuEvt.MTU);
else
// Got an expected GATT message from a peer.
Log_info1("Recevied GATT Message. Opcode: 0x%02x", pMsg->method);
// Free message payload. Needed only for ATT Protocol messages
GATT_bm_free(&pMsg->msg, pMsg->method);
// It's safe to free the incoming message
return (TRUE);
* Application error handling functions
* @brief Send a pending ATT response message.
* The message is one that the stack was trying to send based on a
* peer request, but the response couldn't be sent because the
* user application had filled the TX queue with other data.
* @param none
* @return none
// See if there's a pending ATT Response to be transmitted
if (pAttRsp != NULL)
uint8_t status;
// Increment retransmission count
rspTxRetry++;
// Try to retransmit ATT response till either we're successful or
// the ATT Client times out (after 30s) and drops the connection.
status = GATT_SendRsp(pAttRsp->connHandle, pAttRsp->method, &(pAttRsp->msg));
if ((status != blePending) && (status != MSG_BUFFER_NOT_AVAIL))
// Disable connection event end notice
HCI_EXT_ConnEventNoticeCmd(pAttRsp->connHandle, selfEntity, 0);
// We're done with the response message
ProjectZero_freeAttRsp(status);
else
// Continue retrying
Log_warning2("Retrying message with opcode 0x%02x. Attempt %d",
pAttRsp->method, rspTxRetry);
* @brief Free ATT response message.
* @param status - response transmit status
* @return none
// See if there's a pending ATT response message
// See if the response was sent out successfully
if (status == SUCCESS)
Log_info2("Sent message with opcode 0x%02x. Attempt %d",
else
Log_error2("Gave up message with opcode 0x%02x. Status: %d",
pAttRsp->method, status);
// Free response payload
GATT_bm_free(&pAttRsp->msg, pAttRsp->method);
// Free response message
ICall_freeMsg(pAttRsp);
// Reset our globals
pAttRsp = NULL;
rspTxRetry = 0;
* Handlers of direct system callbacks.
* Typically enqueue the information or request as a message for the
* application Task for handling.
* Callbacks from the Stack Task context (GAP or Service changes)
* Callback from GAP Role indicating a role state change.
Log_info1("(CB) GAP State change: %d, Sending msg to app.", (IArg)newState);
user_enqueueRawAppMsg( APP_MSG_GAP_STATE_CHANGE, (uint8_t *)&newState, sizeof(newState) );
* @brief Passcode callback.
* @param connHandle - connection handle
* @param uiInputs - input passcode?
* @param uiOutputs - display passcode?
* @param numComparison - numeric comparison value
* @return none
passcode_req_t req =
.connHandle = connHandle,
.uiInputs = uiInputs,
.uiOutputs = uiOutputs,
.numComparison = numComparison
// Defer handling of the passcode request to the application, in case
// user input is required, and because a BLE API must be used from Task.
user_enqueueRawAppMsg(APP_MSG_SEND_PASSCODE, (uint8_t *)&req, sizeof(req));
* @brief Pairing state callback.
* @param state - pairing state
* @param status - pairing status
* @return none
uint8_t status)
if (state == GAPBOND_PAIRING_STATE_STARTED)
Log_info0("Pairing started");
else if (state == GAPBOND_PAIRING_STATE_COMPLETE)
Log_info0("Pairing completed successfully.");
else
Log_error1("Pairing failed. Error: %02x", status);
else if (state == GAPBOND_PAIRING_STATE_BONDED)
Log_info0("Re-established pairing from stored bond info.");
* Callback handler for characteristic value changes in services.
uint16_t len )
// See the service header file to compare paramID with characteristic.
Log_info2("(CB) Characteristic value change: svc(0x%04x) paramID(%d). "
"Sending msg to app.", (IArg)svcUuid, (IArg)paramID);
user_enqueueCharDataMsg(APP_MSG_SERVICE_WRITE, connHandle, svcUuid, paramID,
pValue, len);
* Callback handler for characteristic configuration changes in services.
uint16_t len )
Log_info2("(CB) Char config change: svc(0x%04x) paramID(%d). "
user_enqueueCharDataMsg(APP_MSG_SERVICE_CFG, connHandle, svcUuid,
paramID, pValue, len);
* Callbacks from Swi-context
* @brief Callback from Clock module on timeout
* Determines new state after debouncing
* @param buttonId The pin being debounced
// Used to send message to app
button_state_t buttonMsg = { .pinId = buttonId };
uint8_t sendMsg = FALSE;
// Get current value of the button pin after the clock timeout
uint8_t buttonPinVal = PIN_getInputValue(buttonId);
// Set interrupt direction to opposite of debounced state
// If button is now released (button is active low, so release is high)
if (buttonPinVal)
// Enable negative edge interrupts to wait for press
PIN_setConfig(buttonPinHandle, PIN_BM_IRQ, buttonId | PIN_IRQ_NEGEDGE);
else
// Enable positive edge interrupts to wait for relesae
PIN_setConfig(buttonPinHandle, PIN_BM_IRQ, buttonId | PIN_IRQ_POSEDGE);
switch(buttonId)
case Board_BUTTON0:
// If button is now released (buttonPinVal is active low, so release is 1)
// and button state was pressed (buttonstate is active high so press is 1)
if (buttonPinVal && button0State)
// Button was released
buttonMsg.state = button0State = 0;
sendMsg = TRUE;
else if (!buttonPinVal && !button0State)
// Button was pressed
buttonMsg.state = button0State = 1;
sendMsg = TRUE;
break;
case Board_BUTTON1:
if (buttonPinVal && button1State)
buttonMsg.state = button1State = 0;
sendMsg = TRUE;
else if (!buttonPinVal && !button1State)
buttonMsg.state = button1State = 1;
sendMsg = TRUE;
break;
if (sendMsg == TRUE)
user_enqueueRawAppMsg(APP_MSG_BUTTON_DEBOUNCED,
(uint8_t *)&buttonMsg, sizeof(buttonMsg));
* Callbacks from Hwi-context
* @brief Callback from PIN driver on interrupt
* Sets in motion the debouncing.
* @param handle The PIN_Handle instance this is about
* @param pinId The pin that generated the interrupt
Log_info1("Button interrupt: %s",
(IArg)((pinId == Board_BUTTON0)?"Button 0":"Button 1"));
// Disable interrupt on that pin for now. Re-enabled after debounce.
PIN_setConfig(handle, PIN_BM_IRQ, pinId | PIN_IRQ_DIS);
// Start debounce timer
switch (pinId)
case Board_BUTTON0:
Clock_start(Clock_handle(&button0DebounceClock));
break;
case Board_BUTTON1:
Clock_start(Clock_handle(&button1DebounceClock));
break;
* Utility functions
* @brief Generic message constructor for characteristic data.
* Sends a message to the application for handling in Task context where
* the message payload is a char_data_t struct.
* From service callbacks the appMsgType is APP_MSG_SERVICE_WRITE or
* APP_MSG_SERVICE_CFG, and functions running in another context than
* the Task itself, can set the type to APP_MSG_UPDATE_CHARVAL to
* make the user Task loop invoke user_updateCharVal function for them.
* @param appMsgType Enumerated type of message being sent.
* @param connHandle GAP Connection handle of the relevant connection
* @param serviceUUID 16-bit part of the relevant service UUID
* @param paramID Index of the characteristic in the service
* @oaram *pValue Pointer to characteristic value
* @param len Length of characteristic data
static void user_enqueueCharDataMsg( app_msg_types_t appMsgType,
// Called in Stack's Task context, so can't do processing here.
// Send message to application message queue about received data.
uint16_t readLen = len; // How much data was written to the attribute
// Allocate memory for the message.
// Note: The pCharData message doesn't have to contain the data itself, as
// that's stored in a variable in the service implementation.
// However, to prevent data loss if a new value is received before the
// service's container is read out via the GetParameter API is called,
// we copy the characteristic's data now.
app_msg_t *pMsg = ICall_malloc( sizeof(app_msg_t) + sizeof(char_data_t) +
readLen );
if (pMsg != NULL)
pMsg->type = appMsgType;
pCharData->svcUUID = serviceUUID; // Use 16-bit part of UUID.
pCharData->paramID = paramID;
// Copy data from service now.
memcpy(pCharData->data, pValue, readLen);
// Update pCharData with how much data we received.
pCharData->dataLen = readLen;
// Enqueue the message using pointer to queue node element.
Queue_enqueue(hApplicationMsgQ, &pMsg->_elem);
// Let application know there's a message.
Event_post(syncEvent, PRZ_APP_MSG_EVT);
* @brief Generic message constructor for application messages.
* Sends a message to the application for handling in Task context.
uint16_t len)
app_msg_t *pMsg = ICall_malloc( sizeof(app_msg_t) + len );
if (pMsg != NULL)
// Copy data into message
memcpy(pMsg->pdu, pData, len);
// // Let application know there's a message.
* @brief Convenience function for updating characteristic data via char_data_t
* structured message.
* @note Must run in Task context in case BLE Stack APIs are invoked.
* @param *pCharData Pointer to struct with value to update.
LedService_SetParameter(pCharData->paramID, pCharData->dataLen,
pCharData->data);
break;
ButtonService_SetParameter(pCharData->paramID, pCharData->dataLen,
pCharData->data);
break;
* @brief Convert {0x01, 0x02} to "01:02"
* @param src - source byte-array
* @param src_len - length of array
* @param dst - destination string-array
* @param dst_len - length of array
* @return array as string
char hex[] = "0123456789ABCDEF";
uint8_t *pStr = dst;
uint8_t avail = dst_len-1;
memset(dst, 0, avail);
while (src_len && avail > 3)
if (avail < dst_len-1) { *pStr++ = ':'; avail -= 1; };
*pStr++ = hex[*src >> 4];
*pStr++ = hex[*src++ & 0x0F];
avail -= 2;
src_len--;
if (src_len && avail)
*pStr++ = ':'; // Indicate not all data fit on line.
return (char *)dst;
* @brief Extract the LOCALNAME from Scan/AdvData
* @param data - Pointer to the advertisement or scan response data
* @return Pointer to null-terminated string with the adv local name.
static char *Util_getLocalNameStr(const uint8_t *data) {
uint8_t nuggetLen = 0;
uint8_t nuggetType = 0;
uint8_t advIdx = 0;
static char localNameStr[32] = { 0 };
memset(localNameStr, 0, sizeof(localNameStr));
for (advIdx = 0; advIdx < 32;) {
nuggetLen = data[advIdx++];
nuggetType = data[advIdx];
if ( (nuggetType == GAP_ADTYPE_LOCAL_NAME_COMPLETE ||
nuggetType == GAP_ADTYPE_LOCAL_NAME_SHORT) && nuggetLen < 31) {
memcpy(localNameStr, &data[advIdx + 1], nuggetLen - 1);
break;
} else {
advIdx += nuggetLen;
return localNameStr;
UART_init();
Log_info0("\n paramter initialisation");
UART_Params_init(&uartParams);
uartParams.readDataMode = UART_DATA_BINARY;
uartParams.readReturnMode = UART_RETURN_FULL;
uartParams.readMode = UART_MODE_CALLBACK;
uartParams.dataLength = UART_LEN_8;
uartParams.stopBits = UART_STOP_ONE;
uartParams.baudRate =115200;
Log_info0("\n parameter initialising done");
uartParams.readCallback=uartread;
Log_info0("\n reading fucntion passed");
uart = UART_open(Board_UART0, &uartParams);
{ Log_info0("\n be ready");
Log_info0("\n Im here gimme something");
if (uart == NULL)
/* UART_open() failed */
Log_info0("\n uart opening failed");
/* Loop forever echoing */
Log_info0("\n going in now!");
UART_read(uart,&rxBuf1,4);
UART_read(uart,&rxBuf2,4);
