Steps:
1. A terminal(based on TI chip) with a low bluetooth sdk version just supporting legacy pair method.already paired with a headset device.
2. Upgrade to a higher bluetooth sdk version with supporting simple secure pair method.
3. Reconnect between terminal and headset device with same information like linkkey needed by sdk. But connection fails.
a.Use another device same procedure as above, connection succeeds.
b.If downgrade bluetooth sdk to previous version, reconnect succeeds again.
So i want to make sure whether this is related with controller or not ?
Also i attach the two air trace log.https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/538/reconnectFailsAirTrace.7z
