Part Number: FLASH-PROGRAMMER
Other Parts Discussed in Thread: CC2640
Hello.
I am trying to connnect the the SmartRF Flash programmer 2 to my CC2640F128 over its UART. I know the UART connects are good because I can send data to a serial terminal over that connection.
When I try to access the device from the programmer it always crashes when trying to open the prolific COM port (installs to COM7, shows successfully on device manager).
I tried this with a new (erased) CC2640 as well with no difference, so it looks like there is a problem using the driver? (That seems like the case since the program outright crashes).
1) Does this app have a problem with the prolific USB-Serial driver?
2) Is there a way to access the bootloader over UART through code composer or other apps?
