CC2540: CC2540 Tx Power tolerance
Part Number: CC2540
In the datasheet of the CC2540 the nominal max Tx power has been specified to +4 dBm.
The nominal min Tx Power has been specified to - 23 dBm.
Question: what is the worst case tolerance (in the temperature range + voltage range + corner samples) on these typical power values?  +/-1 dB  +/-2 dB?  ....dB?
Kind regards
F.R.
