Part Number: CC2564MODN
Other Parts Discussed in Thread: CC2564
My customer evaluates CC2564MODNEM. He measures an RSSI of -59 to -60 dBm at 1 meter when he would expect -40 dBm. TX level is 0 dBm. Here is his setup:
- Xubuntu 17.10 VM running the Bluez5 stack.
- RSSI measurement with a non-TI BLE module (see notes) configured with 0 dBm TX power
- Console attached to CC2564 with command hciattach -t 250 ttyS0 texas 115200
- Then use the bluetoothctl software, command scan on
- Read the RSSI data corresponding to the external BLE module with bluetoothctl
Please advise if anything should be changed in this setup. THank you.
François.
