Part Number: CC2560
Other Parts Discussed in Thread: CC2564
Does the stack for the CC2560 support delay reporting?
We want to request a the delay / latency from a remote device (headset) that we paired to using the CC2560.
Thank you.
Hi Hari,
I meant CC2560.
We have the CC2564 which does not currently support delay reporting from headset (according to another post from a while ago).
Joshua,
Joshua Thompson said:We want to request a the delay / latency from a remote device (headset) that we paired to using the CC2560.
The delay reporting is an optional feature of the AVDTP protocol and the TI dual-mode Bluetooth stack for CC256x devices does not support this feature. If you are using a non-TI stack with the CC256x device, please check with the stack provider.
Vihang
Hi Vihang,
Which TI chip would you suggest that includes a stack with delay reporting?
Joshua,
I am not aware of any TI stack for classic or dual-mode Bluetooth controller that supports this feature. As I mentioned in my previous post, this is a limitation of the host stack and not the Bluetooth controller. So you may get this optional feature if you use one of the non-TI Bluetooth stacks with CC256x controller that supports the delay reporting feature.
Vihang
