Part Number: CC2652R
Other Parts Discussed in Thread: LAUNCHXL-CC26X2R1
First, tried IoT Quickstart. Using only device ID, the card does connect to Watson IoT Cloud - if briefly. Then cloud reports 'received data from device, but message is malformed'
Various bits of IBM documentation indicate Sensor Tags will no longer connect without TLS/Token.
Where would the authentication token be entered in firmware code? (I'm searching)
