Other Parts Discussed in Thread: CC2560
Hello, does the CC2560 chip have its own built-in antenna? If not, how do we go about making one?
Hi Amar,
First in case there was a typo, the CC2560 is not a bluetooth low energy chip, rather a normal bluetooth chip. In any case, no there is no built in antenna.
You will either need to follow one of our reference designs (once they are posted, unfortunately this is not something I can put on the internet myself) or design in your own 50 ohm antenna.
I hope this helps clarify.
Cheers,
Lisa
The CC2560 does not have a built-in antenna. If you are looking for a complete solution, you may want to have a look at the PAN1315 module (contains the CC2560). They have a module version with an antenna (ENW89818A2JF). http://www.panasonic.com/industrial/electronic-components/rf-modules/bluetooth/pan1315-ti.aspx?cm_mmc=PIC-_-Alias-_-RF_Modules-_-Bluetooth-PAN1315-TI
Rgds,
~MS
