Tool/software: TI-RTOS
project zero of simplelink_cc2640r2_sdk_2_30_00_28.
disable uartlog by changing defined symbles as described in Uartlog.h. change UARTLOG_ENABLE to xUARTLOG_ENABLE, then build will fail at linking for symbols Log_xx not defined.
detail message while compiling:
"../PROFILES/led_service.c", line 218: warning #225-D: function "Log_info1" declared implicitly "../PROFILES/led_service.c", line 233: warning #225-D: function "Log_info1" declared implicitly "../PROFILES/led_service.c", line 238: warning #225-D: function "Log_warning0" declared implicitly "../PROFILES/led_service.c", line 268: warning #225-D: function "Log_info2" declared implicitly "../PROFILES/led_service.c", line 280: warning #225-D: function "Log_error1" declared implicitly "../PROFILES/led_service.c", line 292: warning #225-D: function "Log_error3" declared implicitly "../PROFILES/led_service.c", line 319: warning #225-D: function "Log_info2" declared implicitly "../PROFILES/led_service.c", line 329: warning #225-D: function "Log_error1" declared implicitly "../PROFILES/led_service.c", line 397: warning #225-D: function "Log_info4" declared implicitly "../PROFILES/led_service.c", line 417: warning #225-D: function "Log_error0" declared implicitly "../PROFILES/led_service.c", line 423: warning #225-D: function "Log_error0" declared implicitly "../PROFILES/led_service.c", line 469: warning #225-D: function "Log_info5" declared implicitly "../PROFILES/led_service.c", line 493: warning #225-D: function "Log_error0" declared implicitly "../PROFILES/led_service.c", line 499: warning #225-D: function "Log_error0" declared implicitly "../PROFILES/led_service.c", line 504: warning #225-D: function "Log_error0" declared implicitly "../PROFILES/led_service.c", line 513: warning #225-D: function "Log_error0" declared implicitly Finished building: "../PROFILES/led_service.c"
include of Uartlog.h in the main.c, project_zero.c, button_service.c, led_service.c, data_service.c, c files should be changed according to the statement of Uartlog.h file.
from
#ifdef UARTLOG_ENABLE #include <uartlog/UartLog.h> #endif
to
#ifdef UARTLOG_ENABLE #include "UartLog.h" #else #include <xdc/runtime/Log.h> #endif
