Part Number: CC2650
I have configured my board to use ADC on IDIO 8. I have commented out and removed pins 7 - 14 in the Board.h, CC2650_LaunchXL.h/c files. This works accordingly. However, when I then try to use IOID 12 as GPIO out it fails. Also while debugging I can see that adc on IDIO 8 is not working. Is there something really basic I missed with configuring the pin? Snippets below ->
1. Board.h ->
/* Discrete outputs */
/* These #defines allow us to reuse TI-RTOS across other device families */
#define Board_LED0 Board_RLED
#define Board_LED1 Board_GLED
#define Board_LED2 Board_LED0
#define ChargePin CHARGE_CONTROLLER
2. CC2650_Launchxl.h
#define Board_RLED IOID_11
#define Board_GLED IOID_13
#define Board_LED_ON 1
#define Board_LED_OFF 0
/* Charge outputs */
#define CHARGE_CONTROLLER IOID_12
3. CC2650_Launchxl.c
const PIN_Config BoardGpioInitTable[] = {
Board_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */
Board_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH| PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */
ChargePin | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX,
PIN_TERMINATE
const ADCBufCC26XX_AdcChannelLutEntry ADCBufCC26XX_adcChannelLut[] = {
//{PIN_UNASSIGNED, ADC_COMPB_IN_VDDS},
//{PIN_UNASSIGNED, ADC_COMPB_IN_DCOUPL},
//{PIN_UNASSIGNED, ADC_COMPB_IN_VSS},
//{Board_DIO7_ANALOG, ADC_COMPB_IN_AUXIO7},
{Board_DIO8_ANALOG, ADC_COMPB_IN_AUXIO6},
//{Board_DIO9_ANALOG, ADC_COMPB_IN_AUXIO5},
//{Board_DIO10_ANALOG, ADC_COMPB_IN_AUXIO4},
//{Board_DIO11_ANALOG, ADC_COMPB_IN_AUXIO3},
//{Board_DIO12_ANALOG, ADC_COMPB_IN_AUXIO2},
//{Board_DIO13_ANALOG, ADC_COMPB_IN_AUXIO1},
//{Board_DIO14_ANALOG, ADC_COMPB_IN_AUXIO0},
/* ADC objects */
ADCCC26XX_Object adcCC26xxObjects[CC2650_LAUNCHXL_ADCCOUNT];
const ADCCC26XX_HWAttrs adcCC26xxHWAttrs[CC2650_LAUNCHXL_ADCCOUNT] = {
.adcDIO = PIN_UNASSIGNED,
.adcCompBInput = ADC_COMPB_IN_AUXIO7,
.refSource = ADCCC26XX_FIXED_REFERENCE,
.samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US,
.inputScalingEnabled = true,
.triggerSource = ADCCC26XX_TRIGGER_MANUAL
.adcDIO = Board_DIO8_ANALOG,
.adcCompBInput = ADC_COMPB_IN_AUXIO6,
.adcCompBInput = ADC_COMPB_IN_AUXIO5,
.adcCompBInput = ADC_COMPB_IN_AUXIO4,
.adcCompBInput = ADC_COMPB_IN_AUXIO3,
.adcCompBInput = ADC_COMPB_IN_AUXIO2,
.adcCompBInput = ADC_COMPB_IN_AUXIO1,
.adcCompBInput = ADC_COMPB_IN_AUXIO0,
.samplingDuration = ADCCC26XX_SAMPLING_DURATION_10P9_MS,
.adcCompBInput = ADC_COMPB_IN_DCOUPL,
.adcCompBInput = ADC_COMPB_IN_VSS,
.adcCompBInput = ADC_COMPB_IN_VDDS,
