I am using CC2640R2 with AIC3109 Audio codec. audio play is working with below configuration but audio capture is not working. when i connect i2s audio in and audio out signal then audio loopback is also working.
AudioCodecRegWrite(TI3109_PAGE_SEL_REG,0);
AudioCodecRegWrite(TI3109_SERIAL_IF_CTL_A_REG, 0x00);
AudioCodecRegWrite(TI3109_CLK_REG, 0x01); // CODEC_CLKIN source selection. 0: CODEC_CLKIN uses PLLDIV_OUT 1: CODEC_CLKIN uses CLKDIV_OUT
AudioCodecRegWrite(TI3109_CLK_GEN_CTL_REG,0xa0); //CODEC_CLKIN and PLLCLK_IN is MCLK
AudioCodecRegWrite(TI3109_SAMPLE_RATE_SEL_REG, 0x44);
AudioCodecRegWrite(TI3109_PLL_PROG_A_REG, 0x90);
AudioCodecRegWrite(TI3109_PLL_PROG_B_REG, 0x30);
AudioCodecRegWrite(TI3109_DATAPATH_SETUP_REG, 0x0a);
AudioCodecRegWrite(TI3109_SERIAL_IF_CTL_A_REG, 0x10);
AudioCodecRegWrite(TI3109_SERIAL_IF_CTL_B_REG, 0x00);
AudioCodecRegWrite(TI3109_SERIAL_IF_CTL_C_REG, 0x02);
AudioCodecRegWrite(TI3109_DAC_PWR_CTL_REG,0x80); //DAC power on
AudioCodecRegWrite(TI3109_DAC_OUT_SW_CTL_REG,0x40); //DAC = DAC_1
AudioCodecRegWrite(TI3109_DAC_VOL_CTL_REG,0x0); //DAC not muted
AudioCodecRegWrite(TI3109_PGA_LEFTLOP_VOL_CTL_REG,0x0); //PGA to Left_LOP,left_LOM
AudioCodecRegWrite(TI3109_DAC_LEFTLOP_VOL_CTL_REG,0x0); //DAC_1 to Left_LOP,left_LOM
AudioCodecRegWrite(TI3109_LEFTLOP_OUT_LEVEL_CTL_REG,0x99); //DAC_1 to Left_LOP,left_LOM
AudioCodecRegWrite(TI3109_MICBIAS_CTL_REG,0xc6); //micbias to 2.5v
AudioCodecRegWrite(TI3109_PGA_GAIN_CTL_REG,0x2f); //Select Page 0
AudioCodecRegWrite(TI3109_MIC1P_LINE1P_CTL_REG,0xc4); //micp/m differential add power up
Darshan
