Hi ! I want to use your TI Dual-mode Bluetooth Stack SDK or Bluetopia builds or sources for AM1808. Can you help me ?
Brahman Brahman said:Laird bt830,
Saurabh NarangHi,Which BT chip/SoC are you using with AM18xx ?
Saurabh
By Bluetopia, if you are referring to the TI dual-mode Bluetooth stack, it is licensed royalty free for our customers to use with the TI dual-mode Bluetooth devices (CC256x and WL18xx family of devices). The Laird bt830 does not have a TI controller inside. So no, you cannot obtain/purchase our software to use with a competition device :). Hope this helps!
Vihang
Hi ! I decided to change my BT module laird bt830 to yours cc256 . I will rebuild my device's board for your bt module. I think it will take less time than writing bt stack by myself . :) Ok ? I will use your module. But know can I get builds Bluetopia for Am1808 ? I can change bt module but can't change processor. So I need Bluetopia builds for AM1808.
Hello Brahman,
After further investigation most likely porting will be needed in order to get it to work on the AM1808.
I will send you an email with the details of a 3rd party that can help with such porting.
BR,
Chen Loewy
You said that Bluetopia builds is free for your customers. I am your customer. As I understood you cant port it by yourself . But your 3d party wants 6k $ for port. What is going on ?
