Part Number: CC2640R2F-Q1
Other Parts Discussed in Thread: CCSTUDIO
Tool/software: TI-RTOS
Dear Team,
We would like to have possibility to start the building of the TI-RTOS, an application and BLE stack from command line - because this process must be started automatically from 3-rd party SW tools (automated build system).
On the following link I found something:
http://processors.wiki.ti.com/index.php/Projects_-_Command_Line_Build/Create#Working_with_CCS_Linux
However described under above link commands do not work under UBUNTU 16.04 LTS.
Eg. when I type:
eclipse -noSplash -data /home/wantrych/workspace_v7 -application com.ti.ccstudio.apps.projectCreate -ccs.help
then an error pop-up appears - in attachment please find log file associated to this command.
Questions:
Why it does not work as described in attached tutorial.
Is it possible to build it (TI-RTOS, BLE stack and application ) from "normal" Makefile? - It will be very helpful for us.
Do you have either pdf's or additional description how to do this (Makefile or command line compilation ) to provide ?
