As seen in the below code, I am trying to save the RSSI values of the device being connected, but I am not able to access this value. I am working with the Simple Central Code of CC2640R2F BLE stack.
1. How do I store the value of a device that is not yet connected?
2. How do I store the RSSI value of the device (connected or not connected yet?).
Thanks.
/********************************************************************* * @fn SimpleCentral_processRoleEvent * * @brief Central role event processing function. * * @param pEvent - pointer to event structure * * @return none */ static void SimpleCentral_processRoleEvent(gapCentralRoleEvent_t *pEvent) { switch (pEvent->gap.opcode) { case GAP_DEVICE_INIT_DONE_EVENT: { maxPduSize = pEvent->initDone.dataPktLen; Display_print0(dispHandle, 1, 0, Util_convertBdAddr2Str(pEvent->initDone.devAddr)); Display_print0(dispHandle, 2, 0, "Initialized"); // Prompt user to begin scanning. Display_print0(dispHandle, 5, 0, "Discover ->"); #ifdef FPGA_AUTO_CONNECT SimpleCentral_startGapDiscovery(); #endif // FPGA_AUTO_CONNECT } break; case GAP_DEVICE_INFO_EVENT: { uint8 bAddDevice = FALSE; //ADDED CODE WILFREDO uint8 My_rssi=0; //END ADDED CODE WILFREDO if (DEFAULT_DEV_DISC_BY_SVC_UUID == TRUE) { if (SimpleCentral_findSvcUuid(SIMPLEPROFILE_SERV_UUID, pEvent->deviceInfo.pEvtData, pEvent->deviceInfo.dataLen)) { bAddDevice = TRUE; } } //ADDED CODE WILFREDO// *************************ADDED CODE****** SimpleCentral_addDeviceInfo(pEvent->deviceInfo.addr, pEvent->deviceInfo.addrType); My_rssi=(uint8)( pEvent->deviceInfo.rssi ); //END ADDED CODE WILFREDO if((ENABLE_UNLIMITED_SCAN_RES == TRUE) && (DEFAULT_DEV_DISC_BY_SVC_UUID == FALSE)) { bAddDevice = TRUE; } if(bAddDevice) { SimpleCentral_addDeviceInfo(pEvent->deviceInfo.addr, pEvent->deviceInfo.addrType); } } break; case GAP_DEVICE_DISCOVERY_EVENT: { if(pEvent->gap.hdr.status == SUCCESS) { // discovery complete scanningStarted = FALSE; // if not filtering device discovery results based on service UUID if ((DEFAULT_DEV_DISC_BY_SVC_UUID == FALSE) && (ENABLE_UNLIMITED_SCAN_RES == FALSE)) { // Copy results scanRes = pEvent->discCmpl.numDevs; memcpy(devList, pEvent->discCmpl.pDevList, (sizeof(gapDevRec_t) * scanRes)); } Display_print1(dispHandle, 2, 0, "Devices Found %d", scanRes); if (scanRes > 0) { #ifndef FPGA_AUTO_CONNECT Display_print0(dispHandle, 3, 0, "<- To Select"); } // Initialize scan index. scanIdx = -1; // Prompt user that re-performing scanning at this state is possible. Display_print0(dispHandle, 5, 0, "Discover ->"); #else // FPGA_AUTO_CONNECT SimpleCentral_connectToFirstDevice(); } #endif // FPGA_AUTO_CONNECT } else { if(pEvent->gap.hdr.status == GAP_LLERROR_INVALID_PARAMETERS) { Display_print0(dispHandle, 3, 0, "INVALID PARAMETERS"); } else if(pEvent->gap.hdr.status == GAP_LLERROR_COMMAND_DISALLOWED) { Display_print0(dispHandle, 3, 0, "COMMAND DISALLOWED"); } else { Display_print0(dispHandle, 3, 0, "ERROR"); } } } break; case GAP_LINK_ESTABLISHED_EVENT: { if (pEvent->gap.hdr.status == SUCCESS) { state = BLE_STATE_CONNECTED; connHandle = pEvent->linkCmpl.connectionHandle; procedureInProgress = TRUE; // If service discovery not performed initiate service discovery if (charHdl == 0) { Util_startClock(&startDiscClock); } Display_print0(dispHandle, 2, 0, "Connected"); Display_print0(dispHandle, 3, 0, Util_convertBdAddr2Str(pEvent->linkCmpl.devAddr)); HCI_LE_ReadRemoteUsedFeaturesCmd(connHandle); // Display the initial options for a Right key press. SimpleCentral_handleKeys(0, KEY_LEFT); } else { state = BLE_STATE_IDLE; connHandle = GAP_CONNHANDLE_INIT; discState = BLE_DISC_STATE_IDLE; Display_print0(dispHandle, 2, 0, "Connect Failed"); Display_print1(dispHandle, 3, 0, "Reason: %d", pEvent->gap.hdr.status); } } break; case GAP_LINK_TERMINATED_EVENT: { state = BLE_STATE_IDLE; connHandle = GAP_CONNHANDLE_INIT; discState = BLE_DISC_STATE_IDLE; charHdl = 0; procedureInProgress = FALSE; keyPressConnOpt = DISCONNECT; scanIdx = -1; // Cancel RSSI reads SimpleCentral_CancelRssi(pEvent->linkTerminate.connectionHandle); Display_print0(dispHandle, 2, 0, "Disconnected"); Display_print1(dispHandle, 3, 0, "Reason: %d", pEvent->linkTerminate.reason); Display_clearLine(dispHandle, 4); Display_clearLine(dispHandle, 6); // Prompt user to begin scanning. Display_print0(dispHandle, 5, 0, "Discover ->"); } break; case GAP_LINK_PARAM_UPDATE_EVENT: { Display_print1(dispHandle, 2, 0, "Param Update: %d", pEvent->linkUpdate.status); } break; default: break; } }
